Question about ViewSonic VX2235WM Monitor
Viewsonic va226w monitor get "no signal' when I try to connect to windows xp on a HP/6535 ... Any Help ?
  • 1 more comment
  • frankfrank2 Feb 24, 2009
    yes !
  • Thomas F. Schneider May 11, 2010
    Any chance you could try the monitor on another computer,or a different monitor on yours? This would narrow it down to the monitor or the computer Video section.
    The Viewsonic came with an install disk. Did you install the software?
5 Suggested Answers
  • 6 Answers
SOURCE: windows xp viewsonic vx1962 resolution problem is
The video card determines the resolution you can choose in conjunction with your display.
Posted on Oct 11, 2009
  • 561 Answers
SOURCE: my Viewsonic Va226w is always on standby any ideas
Hi
I would recommend the folloiwng to rule out monitor fault
Please try your monitor on another PC if this works then you have VGA card/drivers issue on your current PC, if this fails on another PC then the monitor is faulty
Please can i ask that you leave feedback and vote if this has been useful
Posted on Feb 10, 2010
SOURCE: LCD monitor (viewsonic va720) "No signal"
Some Laptops or PCs will only work with a 2nd Screen or monitor option on LCD, :Projectors or TV screens.
On Display/.settings/ on PC you can select 2nd monitor option and apply.
U should see your LCD screen flicker and displays your PC 2nd screen
Posted on Jun 27, 2010
  • 225 Answers
SOURCE: Hi , I own a viewsonic
The audiosystem of the monitor has nothing to do with drivers. It is just separate system, like active desktop computer speakers, built into the monitor. Try to find the volume control on the monitor and loud it up. Check the audio controls in the computer - to be in middle positions, not muted. Try to connect headphones to the same computer audio out to check if it works. Try to connect an MP3 player to the audio cable of the monitor to check its speakers.
If you have increased the volume of the monitor, hear the sound trough the headphones but still nothing on the speakers, the monitor have to be opened and fixed.
Posted on Aug 08, 2010
Testimonial: "Thanks a lot...the solution was very informative..I just ignored one small thing .. the audio was muted from my monitor :) thanx again"
Where can I find the right driver to install a Viewsonic VE710b Flat Panel Monitor? I am running Windows 7, 64-bit **This connects to my VGA port, I already have 36" Samsung conntected via HDMI, and
Search Viewsonic.com. The Windows generic driver usually works. If you have a special video driver for your Samsung, it may be interfering. Multiple monitors have to be set up through your display driver. The viewsonic should be available through the device manager.
Oct 10, 2014 | ViewSonic Computers & Internet
I have a Gateway Laptop and a ViewSonic monitor and relocated them into my office yesterday. The ViewSonic was working fine. When I booted everything back up the Viewsonic turns on, flashes my...
It means that there is no video signal from your video card. 1. Check the video cables 2. Try connecting your internal video card if you have one or change the card with new one.
Feb 28, 2011 | ViewSonic VX1935wm LCD Monitor
Hi , I own a viewsonic LCD monitor model va1912w. My system has Windows XP. There is no sound from the monitor even after connecting the sound cable from CPU to monitor's audio jack. I have already...
http://www.viewsonic.com/support/downloads/drivers/?prod_name=1912
Try the above link for Vista or XP drivers which may be used with Windows 7 in some cases.
The va1912wb came up when I searched under 1912.
This driver is available directly from the viewsonic.com site.
Uninstall the other driver if possible.
Aug 08, 2010 | ViewSonic VA1912w 19" LCD Monitor
Windows XP on my Gateway PC will not accept Viewsonic Widescreen VA1912wSeries . My HP PC broke & I moved the montor to the Gateway. The HP had the same Windows XP system.
Reboot the computer into safemode. to do this tap F8 after the logo screen for gateway goes away. select Safe Mode.
Right click the desktop and click properties. in this window click settings. change the resolution to 1024x768.
click the advanced button. click monitor tab then set the screen refresh rate to 60 hertz.
if the monitor is compatible it will be able to be displayed. else try 1440x900 and 60Hertz for the settings
Feb 12, 2010 | ViewSonic VX2035WM LCD Monitor
My Viewsonic Va226w is always on standby any ideas ? trying to connect a HD5770 to it thanks for any help
Hi
Feb 10, 2010 | ViewSonic VX2235WM Monitor
Cpu powers on. Monitor goes to Windows XP and
Dear, This is due loose connection of power cable
(which connect from CPU TO MONITOR). Just check your power, m sure ur problem would be fix out.
Feb 01, 2010 | Generic Memory Compaq Presario SR1215CL by...
No analog signal
Sounds like the graphics card is gone belly up. Try the monitor with another pc or just replace the graphics card.
Hope this helps
Jun 12, 2009 | ViewSonic VX2235WM Monitor
Monitor screen turns off almost immediately
Do you connect all monitor wires on ... Do you got with screen or computer some MSI thing... the monitor blue wire must connect that thing then that MSI or whatever must connect to computer
Mar 08, 2009 | ViewSonic Computers & Internet
Viewsonic VA1912WB error says analog signal
I had a Gateway 19" TFT that did the same thing.
Does the power light stay on? If so, you more than likely have "dry" solder joints at the inverters. Take it apart & shoot a little solder on the inverter solder joints. Good as new now. The solder joints dry out because of the high heat generated. This is a very common problem.
Apr 22, 2008 | ViewSonic VA1912wb Monitor
ViewSonic VX2235WM Monitor Logo
343 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
