Question about Maytag MFD2562KE Bottom Freezer French Door Refrigerator With Ice Box
Why does my water line shake on the back of the fridge?
I have a Maytag French Door Bottom Fridge. The water hose is shaking on the back of the fridge.
  • 14 Answers
Does it shake all the time
Posted on Feb 24, 2009
  • acrman404a Feb 24, 2009
    If the shaking only occurs when your getting water then its most likely a condition called water hammer. Also when the water line (especially if it was copper) was installed on the back it may not have been clamped to the cabnet which will help eliminate the rattle if it is a constant noise your hearing. Sometimes changing the water line to a flexable stainless steel line (Lowes or Home Depot) may eliminate the problem.
Samsung refrigerator dispenser makes noise after filling water glass
You may need to have the water filter replaced. This sounds like it is starving for water as it refills.
Feb 03, 2013 | Samsung RFG297AA (285 cu ft) Bottom...
Ice maker won't work
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
After replacing the water filter on a Maytag refrigerator model mfi2266aeu, I cannot get any water or ice from the in door dispenser. I took the new filter out and put the bypass cap in which didn't work...
Try this
Here is a solution I found for my fridge from another site.
http://www.justanswer.com/questions/2ce1x-maytag-refrigerator-mfi2266aeu
I had to change the Door Alarm button to temp alarm for my fridge Maytag model MFI2266AEW. See if it works for you, it worked for me. I had nothing flashing at all and had to change it to zero but all you need to do is change it back to whatever is on your fridge. My code was inside the fridge, after the word code. It was 4 digits long.
Oct 25, 2009 | Maytag MFI2266AE Side by Side Bottom...
Maytag fridge which freezes food in fridge compartment
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Maytag MFI2569VE Bottom Freezer French...
Ice maker water line shakes with no water being used.
i has to be on cause the motor for the water still trying to **** the water,turn on and will be no problem.if my info was of any help to you please leave a comment,vote,note.thankyou
Sep 04, 2009 | Maytag MFD2562KE Bottom Freezer French...
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
Maytag side by side fridge...water dispenser problem
If the water is visible in the front, more than likely the hose has become disconnected from the door, if you look at the lower left hand corner you should see the hose come from underneath the machine and attach to the door via a plastic quick connect, it is just a push lock connection. You may have to pull of the toe kick and the left hand end cap depending on the model to see this.
Jun 15, 2009 | Maytag MFI2568AE Side by Side French Door...
Crisper door/water line freeze problem
mar...you're box is set too cold. Use -17 C/38 F on the freezer side which is about 38F/4C on the fridge side. Use an outdoor thermometer and let it sit closed for at least a few hours. Adjust accordingly and this will work out. One adjustment is often the cold vents from the freezer into the fridge. If set too wide, too much cold air gets into the crisper and water lines.
Feb 01, 2008 | Maytag MFD2560HES Bottom Freezer French...
Kenmore bottom freezer refrigerator
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Jan 26, 2008 | Kenmore 73503 Stainless Steel Bottom...
Maytag MFD2562KE Bottom Freezer French Door Refrigerator With Ice Box Logo
1,147 people viewed this question
Top Maytag Refrigerators Experts
Richard Roth
Richard Roth
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
