Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Ice on bottom of the freezer
I have a maytag sidebyside water is forming in the bottom of the freezer. Could you please tell me how to locate the drain.
  • lcooley259 Mar 18, 2009
    Water flows from under the unit . The ice cubes do not release and now the water dispenser is not working. This is a lemon!!!!!
  • Maytag Master
  • 3,361 Answers
Your drain is blocked causing the ice in the bottom of the freezer.
The drain is located about 7 inches up from the bottom rear of the freezer.
Just below the back freezer panel.
Turn the fridge OFF.
Remove the bottom bins.
Take a hair dryer and thaw the ice in the drain.
Pour 1/4 cup of bleach in the drain line.
Problem solved.
Posted on Feb 24, 2009
Maytag icemaker drips dirty water onto existing ice ini tray.
please check or install screen filter in the water valve at the back beside compressor
Jan 15, 2014 | Maytag AFD2535
MAYTAG refrigerator
More then likely you have a clogged drain. This is a pain to get to, like most bottom freezer models. You will have to remove everything out of the freezer, remove the door and racks to access the rear freezer panel. Once you get there remove it. You will probably see solid ice forming below the evaporator coil. This is ice from the unit going into a defrost cycle like it should. That is not a problem. The problem is when the ice melts and turns to water it is suppose to drain threw a hole located right below the evaporator in the center. If you have a sheet of ice formed you will need to defrost it to get to the drain hole. You can use hot water. In the industry we de-ice the drain with hot water and then blow it out with a CO2 tank(compressed air tank). This is not my favorite job because it is messy and sometimes long. That ice does not melt fast. Any questions for me go to refrigerator repair and email me anytime.
Apr 09, 2013 | Maytag MFF2558VE Bottom Freezer French...
Water pooling under freezer side of cabinet. Ice forming in bottom of freezer.
drain in bottom fo reezer is frozen w/ice (location is very far left in back lookbehind vent. use hot water and baster. force hot water through drain. /remove ice /it will work good. mm pls leave feed back..mm
Dec 07, 2009 | Maytag MZD2766GES Side by Side...
Ice forming in the bottom of the freezer, not from spilled water.
you probably have a stopped up draing behind freezer wall panel
Sep 19, 2009 | Maytag Refrigerators
My Maytag side by side (no icemaker) keeps leaking water under the freezer side front roller area. Ice is forming on the inside bottom of the freezer under the bottom basket. I've vacummed underneath and...
OK, You need to unplug for a hour or so. Remove the rear panel in back of freezer to expose the evaporator coils. At the bottom of the evaporator there is a tray that catches the defrost water to take it through the back and down to the condensate tray located near compressor and condenser fan. Most likely you have ice or something trapped in that drain beginning in the freezer. I have heard some people turn the freezer temperatures so cold ice will form before the water can drain. If you still have problem contact me. If this helped vote or rate me. Thanks Sea Breeze
Jun 22, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Maytag side by side refrigerator ice forms at the bottom of freez
Your drain is probably plugged. Remove the back panel in the freezer and keep squirting hot water down the drain hole with a turkey baster or something similar until it clears. The drain hole is located at the bottom of the coils in the freezer section. Your refrigerator goes into defrost every 8 to 10 hrs. When this happens, it melts the ice on the coils, which in turn, runs out the hole where the drain is. If something like algae is blocking or plugging the hole, it will plug up causing water to freeze over the hole. The water has nowhere to go but out the door.
Jun 02, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag model MQU1556AEW, frost-free freezer forms ice in bottom.
I'm not sure if this will help but the freezer that is located on the bottom of my refrigerator started forming ice on the back part where the cold air was supposed to be coming out. I kept hearing a hissing sound like water dripping on a hot surface. I called the repair man in and he had to replace the defrost timer. Once he did that it worked like a charm.
I am not an expert by any means although removing ice from a frost-free freezer is a pain and this took care of the problem for me. Good luck!
Apr 07, 2009 | Maytag Freezers
Hi i have a maytag sidebyside fridge/freezer the freezer is filling with water at the bottom and freezing and small amount of water coming out onto the floor occasionally
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Aug 08, 2008 | Maytag Refrigerators
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
483 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
