Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan #2550 farmhand saw, Put a new carburetor on saw still not getting gas to carb?
  • Thomas F. Schneider May 11, 2010
    Bad fuel pump diaphram or pinched fuel line ?.
  • Anonymous Mar 27, 2014
    getting no gas?
    Novelist:
  • 152 Answers
Try emptying the fuel tank, and with small flashlight inspect the fuel line and the sump pick-up screen inside the tank. You may be able to gently retrieve it with a stiff wire hook. See if the hose is cracked/broken of if the screen is clogged. If all is well, be sure there are no kinks in the entire fuel line.
Hope this helps
Posted on Feb 24, 2009
Carb settings poulan 2550 chainsaw, 42cc
Default setting are 1 turn out from in. but chech the metering diaphram as its prob hard..Dont use compressed air to clean
Jul 02, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My poulan chainsaw 2.5 ci farmhand boggs out when choke is turned off?
Check for plugged fuel filter, hard/cracked/rotten fuel lines, plugged muffler and air cleaner, or loose fasteners on the carburetor. If no help, dismantle the carburetor and check the lower rubber diaphragm for hardness or cracking. Make sure to have fresh fuel mix in the tank. If the L jet needle has a slotted-head, a small screwdriver can be used to back out the adjustment CCW about 1/4 to 1/2 turn. If the adjustments have 'D' heads, you will need to take it to a servicing dealer that has the proper tool. Hope some of this helps!
Apr 19, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 2550 change clutch assembly
You do not explain what part or portion of the clutch you need or what problem you are experiencing.
A Poulan "2550 Gas Saw Type 7" IPL example follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2550-Gas-Saw-Type-7/75.2550-Gas-Saw-Type-7.1.59.1.html
If your saw is not a type 7 you can find the correct IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 09, 2010 | Poulan Garden
Fuel line routing
A typical fuel system and a couple of suggestions follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
If not your saw, yours can be found here:
Poulan.com
I am reasonably sure the upper most carburetor connection (it bleeds any air in the carburetor, air rises) goes to the primer. Leave the hoses long enough to swap them and try it. They can be shortened once you verify the correct routing. Good Luck. HTH
Lou
Feb 24, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Craftsman chain saw only runs short time
Craftsman is made by Poulan.
How old is the saw? Have you checked for split fuel hoses? Change the cc to model number (2.2cc Craftsman is often Model 2200 Poulan) and try to find an IPL http://www.ordertree.com/cms/illustrated-parts-list/9788.html. This will show hose routing. As a last resort you may try the "Chainsaw forum here http://www.arboristsite.com/. These are good guys but you will be flamed for buying a homeowner saw.
Lou
I'd put the filter back on.
Aug 09, 2009 | Poulan Garden
I have an 18'' Poulan chain saw that won't start.
Take the wire of the spark plug,and see if it shocks you when the cord is pulled.If not there may be something wrong with your coil.(loose wire for example)If it does shock you,you may want to check out your piston rings,or the little air/fuel mixture valve between your carburetor,and cylinder.
Jun 05, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Poulan chain saw mod. SM4018 Hard to start & won't accelerate
Your carburetor needs cleaned. It may also need a carburetor kit, depending on how old or how long it has been since service. While you have it apart, you may as well clean or replace the air filter and check fuel lines for cracks or brittleness. If you need tips on how to clean carb. or changing fuel lines, just let me know.
Jim
May 30, 2009 | Poulan Garden
Carburetor overflowing
Gas line from primer bulb to carb may be cracked or broken. Check gas lines for damage. If not that then there maybe an overflow problem in side the carb caused by the float shut off not seating correct or worn "o" ring etc.
May 16, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
248 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
