Question about HP Pavilion dv9628nr Notebook
Webcam software uninstalled...
I did a health heck update on my computer and it apparently uninstalled my webcam software. I can not video chat on any program, nor can i locate the webcam on quickplay or anywhere else.
I uninstalled and reinstalled quickplay yet still no webcam software.
How can i get my software back?
    President:
  • 2,692 Answers
Help with Toshiba Satellite L755-S5153 Webcam
What was it working with, the software? What happens when you open the same software it was working with now?
Jan 06, 2013 | Toshiba Computers & Internet
Video calling not be done
The Acer Aspire netbook line comes with a webcam built in to the display panel. This webcam can be used with any software that can access the webcam, such as a video chat program. The cam is in use only when the appropriate software is loaded, so it's not active at all times. The webcam drivers are installed in your netbook, so it should work with most software.
Install a third-party application, such as Skype or Yahoo! Messenger, that offers video chat features. Launch the video chat or messaging software. Select video chat or video calls from within the application to activate your Acer Aspire netbook camera. The camera should load automatically when you select the right option in your third-party software. The camera output displays on your screen and your chat partner's.
b>Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
Dec 08, 2012 | Acer Aspire 5745-5425 Notebook
Error during capture error code 800706f8
The very first step is of course to check your webcam connection. Most webcams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in webcams this steps does of course not apply. Many new laptops have a build-in webcam. Also try connecting your webcam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
windows-xp-other-device.jpg If the device is not recognized in Windows XP, it will be listed under Other Devices.
windows-vista-device-error.jpg In either case you can try to update the drivers. Right-click the device, and in the popup menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the webcam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to uninstall the software that came with your webcam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party uninstaller.
After uninstalling the software, restart your PC and then reinstall the webcam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your webcam during the software installation.
If the drivers and webcam software are correctly installed, and you still cannot see any video, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the webcam feature. If you have multiple devices that qualify for video, you might need to select your webcam device as the source for the webcam feature in that program.
Lastly, if your webcam's image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Other picture quality problems with webcams can be addressed by changing the video capture properties for the webcam. Most programs that can use a webcam will have an option to access the properties of the video source, which will bring up the video capture properties window.
video-capture-properties.jpg Do keep in mind that not all settings will be enabled depending on the webcam and the webcam driver installed on your computer. In the example you can see that some settings are disabled. The example shows the video capture properties for an Acer Crystal Eye webcam.
What else to try: download missing webcam drivers! If you are using your webcam for instant messaging with one of the popular chat programs, have a look at EatCam, which allows you to record your webcam chats from MSN, YM, ICQ, Skype, AIM and a few more!
Mar 05, 2011 | Computers & Internet
After having successfully installed, and used my Microsoft LifeCam HD-5000, Google Video Chat experienced some sort of error, and as a result my webcam is no longer recognized by my computer (so says the...
Copy this site and paste it in your ADDRESS Bar and Hit ENTER to get the Gtalk Plug-in for "Voice & Video Chat
http://www.softpedia.com/get/Internet/E-mail/Mail-Utilities/GMail-Voice-and-Video-Chat-Plugin.shtml
Google just release a new chat functionality for Gmail, this is a new video and voice chat plug-in that will let us to see and hear our family, friends and contacts from within Gmail with a high quality audio and video.
To start using this new functionality you just only need to download and install the new Gmail voice and video chat plug-in and a webcam.
The voice and video chat plug-in for Gmail is free and only works with the newer version of Gmail in supports Browsers FF 2.0+, IE 6.0+, Safari 3.0+, and Google Chrome.
BTW, the video and voice plug-in only can be installed on Windows XP or later.
For more information and Download the Plug-in please visit the Gmail voice and video chat page.
Click on "Voice and video chat"
It's free and installs in seconds
System requirements:
· Windows XP or later
· Intel Mac OS X 10.4 or later
· Chat more ways than ever from within Gmail
· Look and sound your best with high quality audio and video
· Get started easily -- all you need is a webcam
Hope this helps. Bud
Jan 28, 2011 | Microsoft LifeCam HD5000 Webcam
Can i access free software for this webcam
Visit the Logitech website and browse the photo gallery for your model and click on the photo to navigate to the support page.
Note - Older models on page 2 - look for the link at the bottom right of page 1 and click on it "Still can't find your product?"
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
In addition to the Logitech installer you will need to check the support software - Microsoft DirectX . This comes pre-loaded on most Windows computers but has to be updated - I am currently on version 11
To start the DirectX Diagnostic Tool, click 'Start', click 'Run', type dxdiag in the Open box, and then click OK
Run through the tabs checking the 'notes' windows for information
The version will be shown on the 'Systems' tab
Procedure to re-install Logitech software
Close all programs while uninstalling - downloading and uploading software
Disconnect your webcam
Uninstall the current webcam software on your computer
Restart computer
Download the Installation package from Logitech
Run the installer and choose your options during the installation - You may not want Logitech Chat but the Desktop icon for the webcam toolbar is a must.
Connect your webcam when prompted.
Sep 04, 2010 | Logitech Quickcam Chat Webcam
I have a distorted picture and Windows XP is my oS?
Logitech
1) Clean the lens
2) Launch the Logitech toolbar. Open the Video Effect menu (2 theatre masks) and make sure no video effects are applied
2) Check your DirectX
3) If thats OK uninstall the Logitech Software and re-install
To start the DirectX Diagnostic Tool, click Start, click Run, type dxdiag in the Open box, and then click OK.
Run through the tabs checking the notes
Restart computer
Aug 31, 2010 | Logitech Webcam
My logitech webcam has very poor picture and a 2 second delay when i am video calling.
Start your troubleshooting by updating your software
In addition to the Logitech installer you will need to download Microsoft DirectX 9 or later to support your webcam
Procedure
Restart computer
Aug 22, 2010 | Logitech Webcam
I've had my Logitech webcam for about a year. I experienced a crash after trying to install an update. I have reinstalled the program, but the camera is not capturing video. It will not allow me to adjust...
Try updating your Microsoft Directx - I have version 10 installed - Skype requires version 11
next step would be a re-install
Procedure
Restart computer
Run the installer and choose your options - You may not want Logitech Chat but the Desktop icon for the webcam toolbar is a must.
Aug 06, 2010 | Logitech Quickcam Chat Webcam
No video when using quickcam pro 9000 on google chat (gchat)
I had this problem but I fixed it. The google chat uninstaller does not uninstall everything. Go to the hidden folder Application Data of the default or local user in the Documents and Settings folder of the C drive, you will find the plugin folder for google chat. Delete it and then reinstall the plugin and it will work.
C:\Documents and Settings\Joe\Application Data
Dec 06, 2008 | Logitech QuickCam Pro 9000 Web Cam
HP Pavilion dv9628nr Notebook Logo
150 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
