Question about Maytag Atlantis MAV8551 Top Load Washer
Our washer fills with some water when not in use.
The washer works fine, except after a cycle is done, clothes are removed, the washer is empty of water, the cover is closed and the next morning there will be 2-3 inches of clean water in the bottom of the tank.  Thus it fills with water when not in use.  Looks like it could be a leaking check value of some type??
    President:
  • Maytag Master
  • 2,651 Answers
A faulty inlet water valve, the valveis not fullly closing causing water to trickle in, replacethe valve ( in the meantime turn off the water inbetween unsage)
Posted on Feb 24, 2009
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Cold water pours in during final spin
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Maytag Atlantis MAV8551 Top Load Washer Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
