Question about StarTech.com StarView SV211K 2-port KVM Switch
Lost some channels
Is it auto scan you do when you have lost some channels to get them bac ?
  • ghalie_s Mar 01, 2009
    lost most of my channels, have done auto scan and blind scan but nothing seems to come back
    President:
  • 159 Answers
Hi, try this,Try Menu--Installation--Manual Scan--Down Frequency 000000--Network Scan (L/R arrow)Enable
Wait a moment Press OK
Posted on Feb 24, 2009
How so u auto scan a Sanyo led without remote control
Many TVs require a remote control to access any function other than Vol+/-,Ch +/-
Apr 23, 2016 | Sanyo 42 in. LCD TV
Lost data for channels
do an auto scan thru the main menu
Feb 28, 2015 | Cell Phones
Lost ABC channels on retune, how do I regain reception
Try manually entering the channel number. Many TV's have, besides autoscan, a way to manually add or remove channels.
(Besides, what is worth watching on ABC? (;^D)
Oct 21, 2014 | Televison & Video
Run channel auto scan
The auto scan feature scans the various channel frequencies looking for a signal. Weak signals may be picked up on one scan and missed on the next. Check your antenna or add a antenna power booster and try again.
Sep 18, 2013 | Sony BRAVIA Televison & Video
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Oct 07, 2012 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
Incomplete Auto Scan of the channels
I ran the Auto Scan. Before the scan reached 91%, I pressed the Menu button on my remote and all of the channels that it found locked in.
Jan 07, 2010 | Westinghouse LTV-27w6 27 in. LCD HDTV
Lost certain channels on Eurovox
run auto scan......please make sure you dont run power scan.....once scan is done you should get all the missing channels back.
Jun 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Loss of starview channels
Try and determine the lowest transponder frequency that you can get a signal on.
Look at the frequencies you already have on the channels saved so far and choose the lowest.
Then in the installation menu select MANUAL SCAN and set that as the frequency.
Make sure you can see a signal and scroll down to Network scan and change to ENABLE with the Right arrow.
While still highlighted, click OK.
Scanning should then begin. It will say 1/1 to start with but should then jump up to 1/?? (the ?? being 2 digits).
Using this method indicated it scanned 56/56 transponder frequencies as opposed to 48 in Auto scan on one main provider.
Dec 10, 2008 | StarTech.com StarView SV211K 2-port KVM...
I can not prongram my Real Digital RD2200 LCD TV
If you are using a cable box you will put you TV on chan 3-or 4 and use the box as your tuner. if you don't have a cable box it may be that the cable is at fault. The auto scan looks for any channel signal and will delete unused channels and lock in the received ones. If no channels are there only the strong ones will lock. The tuner in your TV works in bands or groups of channels and if it was a bad tuner the set would still find all the channels in the low / mid or high bands.
Jul 03, 2008 | Televison & Video
StarTech.com StarView SV211K 2-port KVM Switch Logo
57 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
