Question about Kenwood KAC-719 Car Audio Amplifier
Only one side works and know it all worked when i took it out
I have a kenwood kac 819 450 sevo amp and woul like to know if there is a diagram i can look at to make sure im hooking it up right....
  • 41 Answers
Car amps are generally fairly simple to wire you need;
Battery Positive (large wire)
Ground (large wire)
Remote signal (small wire)
RCA In and/or Hi-level in
Then you generally have a set of screws or clips that are your speaker outputs.
To see if the problem is on the input or output side, simply switch your RCA cables and see if the audio starts coming out the other speaker.
If it does then you have an input problem and you should check to see if your RCA's are still plugged in to the head unit at the dash.
If the sound still just comes out the same side then you have an output problem and should check your speaker connections, verify that you subs are still good by switching the output wires on the amplifier, and check the wiring inside the speaker box.
Posted on Feb 24, 2009
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood Excelon KAC-X811D blinking e-03
Hello mogly20,
The amp probably won't know if it's you or the homeless guy, so try smashing a glass bottle on it like he did. If that doesn't work, I'd recommend you locate another homeless guy and buy another amp.
Hope this helps.
Aug 08, 2009 | Kenwood Excelon KAC-X521 Car Audio...
To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Need help kenwood kac-9152d
This has been answered on a previous post!
Click Here to be redirected
Upfront Audio :)
Apr 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Mar 22, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Amp wont turn on
Double check all of your connections. I know this same problem has happened to me and come to find our that all the problem was the fuse blew that is connected between the radio and amp. Also check you battery connection. Corrosion on the power cable will also cause it to have a bad connection.
Mar 15, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Cant get but one side to work
This amp (kenwood  819)  was designed for use with a sub-woofer, hence the single chanel. It will however power up 4 speakers in mono, and if they are capable of handling the amps.while robbing you of the benefits of stereo as well as left, right and fade control.Good luck...
If you still want it connected. You should purchase an amp installation kit, and review the topics and videos at this web site. www.installdr.com
Good luck...
Feb 24, 2009 | Kenwood KAC-819 Car Audio Amplifier
Kac-8404 100w amp
What are the numbers on the transistors?
Jan 06, 2008 | Kenwood KAC-8401 Car Audio Amplifier
Amp Turns on... then off
unplug all speakers and see if it still into protect .If unit powers up normally without speakers , then hook up a temporary speaker directly to speaker out to see if you have output.If it works .Then check speaker cables and speakers for shorts.Also make sure you have good ground and main power and standy are present.
Nov 30, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-9152D problem
It sounds to me like you may have burnt a trace off of the bottom of the circuit board inside the amplifier. If you know how take the amplifier apart and look carefully at the traces. To be clear the traces are the lines on the bottom of the circuit board not the component side. Look carefully they can sometimes be hard to spot. If you find one solder a jumper wire across the two points. If you take the amplifier apart take care in treatment of the output transisors along the sides.
Jan 17, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-719 Car Audio Amplifier Logo
125 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
