Question about Kodak EASYSHARE 5100 All-In-One Printer
Need to know how to put in a print head - Kodak EASYSHARE 5100 All-In-One Printer
Dear angie
Turn printer on
Raise scanner lid (grey KODAK lid)
Watch print cartridges automatically center and stop
Remove each cartridge (pinch the lower lip to upper)
Put index finger on printhead 1/2 inch above bullseye - on underside of upper bar - below the 1/2" slot in printhead
Find 1/2" "button" and push firmly; printhead snaps loose
Tip forward and lift printhead out
rlmontgom
Posted on Feb 24, 2009
Hello, our C66 printer won't print. It has been unused for about 2 years, we've put all new ink cartridges in, downloaded the latest drivers, and nothing gets printed. You can go through all the test...
The most likely cause is the print head nozzles are blocked with dried ink and inserting new ink cartridges won't fix this problem. You need a new print head.
Print heads are not cheap, you may be better putting your money towards a new printer.
Jan 06, 2011 | Epson Stylus C66 Inkjet Printer
Prints blank pages when I try printing a document
Hi
Some times it needs a good clean up but this is up to you if you want to do this I put down here. But after you don this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Brother Multi-Function Center MFC-240C...
Done all the things you advise to clear the print heads, it seems to relate to the large back cartridge, ink flow seem ok, sponge pad at base of cartridge moist with ink. All other inks fine on test print....
Yes, the print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0075.
Nov 13, 2009 | Canon MP610 Photo All-In-One Printer
Wont print black text Is this the 3ebk or the 6 bk cartridge that isn't working, and how might I resolve the problem?
The print head is clogged.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Nov 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Nothing printed page is blank, all new ink cartridges lit up red
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0059.
Nov 02, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Black Ink won't print on my Cannon ip90 Printer
Here's the link to the transcript..
http://www.fixya.com/support/c36778-black_ink_print_cannon_ip90_printer
Please post your comments there if you are not able to reconnect to the session with me..
Mar 20, 2009 | Canon PIXMA iP90 Mobile Printer
Printer will not print black ink.
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. May color and black and white print is back!
Hope this helps.
cw
Feb 16, 2009 | Canon PIXMA iP90v InkJet Printer
IT COMES UP PUT IN CARTRIDGE
my print head had to be replaced it was $112 so i will see if the printer expert was right.i didn't have to pay for this person to tell me ,i first took my print head to a cartridge refill place at wynnum,CARTRIGE WORLD and with his experience he could tell it was the print head that had to be replaced.
Oct 08, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Does anyone know how to remove print head?
The print head nozzles is clogged but good. None of the cleaning the machine can do will clear it. Been there and trid that. Doesn't work. The clogs need to be dissolved with a specialty clog buster and probably will need to soak at least 24 hours, maybe more. Don't deep clean any more as you will put so much in in the absorbent blotters on the inside of the printer that you will trigger an error code and not be able to print until the absorbant pads are replaced by a service tech for about $100.
Aug 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer won't print using black
the absorber should be cleaned and sometimes you have to set the print heads in just right or get no color at all
there is also a solution called priming your print head a little rubbing alcohol on the print head with cotton swab to see if the ink runs on swab
May 22, 2008 | Office Equipment & Supplies
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
