Question about Hoover U5227-930 Elite Upright Vacuum
Kenmore Intuition Vacuum # 28014 (canister)
I cannot take the telescopic handle from the base of the vacuum. There is a quick release that enables this handle to come off in order to vacuum with the attchments in high places (celilings). I notice that there is a small crack in the plastic underneath the quick
  • Linda Cope Feb 24, 2009
    Also, is there any place that I can obtain a "users manual" with operating instructions? Thank you!
    If no one has a solution, does anyone have suggestions as to a good repair place in the "west of Boston" area? (Natick, Wellesley, Framingham) Thank you again!
    lmcope1
LizDahl
  • 75 Answers
SOURCE: electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Posted on Jan 12, 2008
  • 126 Answers
SOURCE: Brush won't spin when position of handle changes
The belt for this machine is very specific and only one size fits. It is not uncommon for vac shops to sell the wrong belt because the proper belt is not available from normal supply houses, so they will substitute something they think will work.
Also, assuming you do have the right belt, check the tension arm that drops down on the v-belt when the handle is brought back. This arm has a wheel/bearing with a plastic "tire" or trim that rolls on the belt to tighten it. Sometimes, this tire cracks and falls off and then the remaining bearing won't have the necessary tension to tighten up the belt.
Posted on Jan 27, 2008
  • 4 Answers
SOURCE: No suction on kirby g4 upright vacuum. Can't use attchments.
First remove the mini-emptor and check for a clog also check the fan for anything cloging that or the hose may be clogged
Posted on Jul 10, 2008
SOURCE: Hoover Self Propelled wind tunnel vacuum U6433-900
I need to replace the actuator pivot arm on my Hoover Wind Tunnel to fix the self propel feature. I can see where it needs to go but I can not seem to get the cover off the vacuum so I can get to it. How do I do this?
Posted on Sep 16, 2008
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
When I replaced the bag, the bag replace light comes on unless I don't use any attachments. what is the problem?
Could be a blockage, push a broom handle through the pipe that will clear it.
Oct 18, 2014 | Kenmore Vacuums
I have a Kenmore "Intuition"
I had a different vacuum that did this. I took all manner of things apart looking for blockages and the like .I found that by having the vacuum handle in the full upright position shuts off the suction to this area and doesn't power the brush BY DESIGN. I think this is to get more suction to the hose.
Dec 18, 2017 | Kenmore 25512/ 25513 Progressive Canister...
My Kenmore progressive canistor vacuum has a loose electrical conection in the hose handle. How do you take the handle apart?
There are 3 visible screws there in the handle and one not so visible.
start by removing the 3 visible screws.
Take a flat screwdriver and pry off the colored portion of the handle that would contain the switch.
There is one more screw in the handle just in front of the switch, remove that one.
This is where it gets tricky.
under the handle between the handle and the hose, is a little square shaped pry area that is locked. Use the same flat screwdriver to get at that and release it. The rest of the handle should come apart pretty easy now.
Good luck.
Mark
Nov 11, 2010 | Kenmore 25512/ 25513 Progressive Canister...
My kenmore quick clean vacuum cleaner has no suction. Just seems to blow the dirt out and away from the cleaner. The canister is empty and the filter is clean, so what's going on?
The hose or hoses are plugged...take all the hoses apart and stretch them out... run a stiff wire through them or something like a broom handle...you will find that they are full of dust and dirt inside...
heatman101
Apr 24, 2010 | Kenmore Quick Clean 30012 Vacuum
My Kenmore 116.25812508 power nozzle motor will not run unless I tilt the handle. I checked the connectivity from the circuit board in the power nozzle base to the telescoping wand with an ohm meter and...
I have had this vacuum for about 3 yrs and nothing but issues with it. It's been in the shop already once and it needs to go again. No power in the power head. A wheel came off of the powerhead too .. keep snapping it back on but it always comes off.
I am disgusted with this vacuum
Jan 19, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
Failed telescoping tube lock. Will not release
It is stuck because it is full of gritty dirt. Like the guy said, don't force it, get a bigger hammer.
Serioiusly, you can use a hammer to tap along the handle to loosen the gritty dirt and probably get the parts to release.
thanks for posting at FixYa.com
Dec 12, 2009 | Miele Cat & Dog 326i Bagged Canister...
Kenmore Quick Clean - how to remove dirt from cannister
this is the web site for Kenmore owners manuals
--->http://www.managemyhome.com/mmh/<---
Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Kenmore Quick Clean 30012 Vacuum
Motor goes on and off briefly at regular intervals
Sounds like you may have a bad or loose connection, could be one of wires in the hose to the handle harness or the harness itself may be causing the problem. Also be the motor or relay causing a problem.
Jan 08, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Hoover U5227-930 Elite Upright Vacuum Logo
1,339 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
