Question about Whirlpool Kitchen Ranges
We have a Whirlpool model WDP58803 electric range.
We have a Whirlpool model WDP 58803 electric range. The oven door pull handle is coming a bit loose. How do I get into the door behind to tighten it up?
4 Suggested Answers
SOURCE: I have a kitchenaid electric range and the oven
My son came and pulled the door straight out not up and we were able to take it off and take it apart and tighten the handle and clean the inner glass. It now looks and works like new.
Thank you
Karen
Posted on Aug 09, 2009
EllaWatson25
  • 725 Answers
SOURCE: oven handle for 465 electric stove
Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST for all your appliance parts and supplies.
We ship overnight to our customers. Thanks, Ella
Posted on Nov 17, 2009
  • 105 Answers
SOURCE: The screws holding the handle on the oven door
Without a model #, I would say you need to take the oven door off and disassemble it to get at the screws holding the door handle. Some models have screws going right through the door to hold the handle on. Best of to call a certified repair company such as Sears.
Posted on Mar 20, 2010
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The screws holding the handle on the oven door have come loose. How do you get at the screws to tighten them? It is a Whirlpool range designer model.
Mar 20, 2010 | Kitchen Ranges
I did a self clean on my tappan electric oven; cant get the door to open.... what can i do?
MaryAnn, If you try to push the locking lever/handle towards the "lock" position first, then pull it back towards the open position, it should unlock for you.
However if that doesn't work, you can turn off the breaker for the electric range, in most electric panels, it is marked as "Range" or "Stove" but is typically a double pole 50 Amp Breaker (It takes up 2 spaces). If you look at the handles of the breakers, you should be able to see the numbers "50" on the handle.
Once you turn off the power, you should be able to unlock the oven. Some ranges require that the power be on in order to unlock it, but first try to open it with the power turned off, and it that doesn't work, turn the breaker back on and the door should be able to be unlocked.
Remember that it will take a little bit of effort to get the door to unlock in some cases, so give it a good tug.
Hope you find this Very Helpful and best regards!
Oct 25, 2009 | Tappan Ovens
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
My oven door came off and I can't get it back on
I have spilt milk flowing down the side fo oven/counter top and needed to pull out the stove to quickly get it wiped up..I pulled the stove out by the oven door handle. The hinge sprang on the right side and the oven door is now off on one side how to get it back on?? My husband lifted the door up and the whole door is now off.
It is very difficult to replace, what are we doing wrong???!!! Please help. I belive it is a whirlpool electronic model. thankyou.
Jan 08, 2009 | Jenn-Air JER8850 Electric Kitchen Range
Self cleaning oven directions
MAKE SURE OVEN IS EMPTY LOCK OVEN DOOR AND TURN OVEN SETTING TO CLEAN, IF YOU HAVE A VENT TURN IT ON THERE WILL BE SMOKE! LET RUN TWO HOURS,TURN OFF,LET COOL BEFORE TRYING TO UNLOCK IT (WILL NOT UNLOCK WILE STILL HOT!) OPEN DUST OUT ASH ITS CLEAN!!!
Dec 07, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Stove won't unlock
some of the kenmores have the door lock motors in the back behind the large panel slide out an remove panel an pull or push the rod to unlock door if motor is bad for a temp fix just remove rod
Aug 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Stove handle/door
need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
Feb 26, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
Kitchen Ranges Logo
46 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
