Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune will not sync with my notebook.
Just restart your zune by holding back and up on the pad at the same time. This worked for me as well. Takes 30 seconds.
  • 66 Answers
When Zune program is open right click on the zune from the panel and look through the settings...I believe you should fine the syncing option there
Posted on Mar 12, 2009
The usb connected icon that sits on bottom right of the task bar say its connected but may not work properly and windows starts making the default sound for connecting and unconnecting as the zune resets...
I would recommend you to hard reset the player using the instructions below:
WARNING: A hard reset will delete everything on your Zune.
  • Press and hold the back button
  • Press and hold up until it reboots
  • Depending on which Zune you have, immediately do one of the following:
  1. If you have a Zune 4 GB, Zune 8BG, or Zune 80GB, immediately press and hold the Back button Back at the same time as you press the right side of the Zune pad and the Play/Pause button. Continue to hold these buttons until the Zune device restarts and you receive the following message: "Clearing contents. Please wait."
  2. If you have a Zune 30GB, immediately press and hold the Back button Back at the same time that you press the right side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until the Zune device restarts and you receive the following message: "Clearing contents. Please wait."
I hope the above steps would help resolve the issue.
Please revert back for any more issues that you may face.
Regards
Anand
May 10, 2011 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune won't sync and now some songs will not play all they way through
Go for software update from the zune website it will help you.
Also ensure that the settings are not changed .
Sep 25, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune will not turn on
1. If the Zune device is not connected to a power source, set the Hold switch to unlocked. Then, press and hold the Play/Pause button to turn off the device. • If this does not work, restart the device. To restart the device, set the Hold switch to the unlocked position, and then press and hold the Back button zune_button_back.gif as you press the top of the Zune Pad. When the device begins to reset, you can release the buttons. 2. If the Zune device is connected to a power source, it is operating correctly. You cannot manually turn off the Zune device. Note Depending on how you configured your backlight setting, the backlight for the Zune device may automatically turn off in this situation. To access the backlight options, select display on the settings menu, and then press the center of the Zune pad. To adjust the setting, select backlight, and then press the center of the Zune pad.
Mar 21, 2008 | Audio Players & Recorders
I want to start over with my Zune Model 1089. I want to clear everything off of it and start over. Please help....
1. Slide the "hold" switch so that it is in the unlocked position. 2. Press the "Back" button and the top of the Zune pad at the same time and hold until the device resets and begins to power up. Release the buttons when the Zune starts to power on. 3. Immediately press and hold the "Back" button and both the left side and the center of the Zune pad and continue to hold until the Zune restarts. The phrase "Please Wait" will appear on the LCD screen. Release the buttons.
4.Let the Zune continue resetting. It will clear the contents and eventually display "Connect Zune to your PC" when it is ready.
5. Connect the Zune to your PC via the sync cable. Follow the prompts given by the Zune software to completely restore the Zune device to the factory settings. If you have downloaded newer Zune firmware, you have the option to restore the Zune firmware with the latest version.
Mar 06, 2011 | Microsoft Zune JS8-00001 Digital Media...
How do I restore my devices firmware for my zune 30gb
How to restore your Zune device software:------------
When you restore your Zune device software, the startup partition and the data partition are removed and rebuilt. In addition to removing the Zune device software, this process also erases all audio, videos, podcasts, and pictures that are stored on the Zune device.
Warning To restore the Zune device software, you must have a Windows-based computer that has an Internet connection. That computer must have the Zune software installed. And you must be able to connect the Zune device to a USB port on that computer by using a Zune Sync Cable. Do not perform the following steps if you do not have any one or more of these things immediately available.
After you start to restore the Zune device software, you cannot again use the device until you complete all the steps. You will not receive any confirmation or warning on the Zune device after you start the following procedure.
To restore the Zune device software, follow these steps:
1. Set the Hold Switch to unlocked.
2. Press and hold the Back button at the same time as you press and hold the top of the Zune Pad. When the Zune device begins to power up, release the buttons.
3. Immediately after you release the buttons in step 2, press and hold the following special button combination, depending on your Zune model:• If you have the 4GB Zune, the 8GB Zune, or the 80GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune Pad and the Play/Pause button. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
• If you have the 30GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
Note "Clearing contents. Please wait" appears, followed by “Connect Zune to your PC."
4. After “Connect Zune to your PC” appears, connect the Zune device to the computer that has the current Zune software installed, and then update the device to the current Zune device software.
----------- Click this link directly for more troubleshooting:-- http://support.microsoft.com/kb/944909 -------- If error problem while restoring then click this link below:-- http://support.microsoft.com/kb/945278 ---------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 03, 2010 | Vacuums
Error code c00d124d appears on my zune while sync
You may have to attempt a Hard Reset if this issue is persistant.
This will erase everything on your device, as a warning please be certian you have backup copies or this is a last resort.
Here is the original post:
  1. Press and hold the back button
  2. Press and hold up until it reboots
  3. Depending on which Zune you have, immediately do one of the following:
    1. If you have a Zune 4 GB, Zune 8BG, or Zune 80GB, immediately press and hold the Back button Back at the same time as you press the right side of the Zune pad and the Play/Pause button. Continue to hold these buttons until the Zune device restarts and you receive the following message: “Clearing contents. Please wait.”
    2. If you have a Zune 30GB, immediately press and hold the Back button Back at the same time that you press the right side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until the Zune device restarts and you receive the following message: “Clearing contents. Please wait.”
    Good luck, Let us know
Apr 14, 2009 | Computers & Internet
Zune Backlight
It happens to my Zune often. Don't Worry. Reset your zune. Now hold the back button while holding the upper part of your touch pad, when it starts to reboot immediately connect it to your computer. Continue to restart your zune again and again (i.e back and upper part of touch pad) and keep on unplugging and plugging it to your computer. It will work out. I'm SURE. This happened to me, I tried this method and it worked but after I restarted the zune 4 times!!!
Jan 31, 2009 | Microsoft Zune JS8-00001 Digital Media...
Stuck on startup screen.
pull the case apart and pull the battery out for about thirty seconds. put it back in and back together and it should work.
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune
To reset the zune you must press and hold the back button and the top part of the zune pad. Other parts of the zune pad will not work.
When plugging the zune into your PC does the PC detect it (device manager -> portable devices). You should hear the ding sound of hardware connecting.
If it is connecting to the PC and is not detected by the software than it is likely a permissions problem. Right click the software icon and choose run as administrator.
If it is not detected by the PC than check your usb cable and make sure your zune is charged and not frozen.
May 29, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune will not sync
Okay... what you do is Hold your zune in you right hand.. open the toilet bowl with your left.. put the zune in the toilet... and then flush it... or if you have not gotten a zune... just throw the $200+ in the toilet instead.. Because i have the same exact problem as these guys and none of their solutions have worked..
Feb 04, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
48 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
