HP Business Inkjet 2230 Printer
Problem for HP Business Inkjet 2230 Printer
IPrint status and HP Business Inkjet 2230/2280 printers..
By Jimmy NY - usenet poster
We have about 15 or so networked HP Business Inkjet 2230/2280 printers
that are available via iPrint..
They all work fine, but they all state a status of error in the status
column.. This confuses alot of people.. We had tons of other networked
printers laserjets and deskjets and they all work but the 2230/2280 series..
They all have internal HP jet direct cards..
Any ideas?
Thx
Jeremy
Solution #1
posted on Sep 14, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
We have this problem and we remove snmp configuration. Everythyng work well... except snmp :-)
Solution #2
posted on Aug 02, 2007
Not Rated)
Luisa_K
Rank: Apprentice
Rating: 0%, 0 votes
Will have to setup on our test server for the HPGate stuff..
We are running 6.0sp4.. We don't use iManage 2.x yet (using 1.2.2)..
Not sure what that gives us..
Just a little more info, when I manage the printer I get the display as
follows:
Display Panel: READY
Printer State: Error Printing
Other Problem:
The other weird item I notice (only on this model printer) is:
Printer Model Printer Manufacturer
From Printer ???HP BUSINESS INKJET 2280 (unknown)
See the funky characters next to HP, than it can't figure out
manufacturer...
You don't happen to know how Novell finds out the printer model do you?
I have spoken with HP about this and they aren't the most helpful bunch.
Thx!
Jeremy
Was this helpful?
Yes
No
Solution #3
Not Rated)
Bouncy
Rank: Apprentice
Rating: 0%, 0 votes
I think that is true for NW6.5, but I can manage mine OK in NW6/SP3.
Probably it's really an issue of the version of iManager. Pre 2.0.2 should
be OK, I think.
Could be the Novell SNMP Gateway doesn't quite correctly decode things
correctly. HPGATE should have a better shot at it.
What version of NetWare, including Support Pack?
-Barry. [Novell Support Forums SysOp]
Was this helpful?
Yes
No
Solution #4
Not Rated)
Brad
Rank: Apprentice
Rating: 0%, 0 votes
We could try the HPGATE, the big downfall there is I understand you
can't use iManage to manage thr printers then..
The JetDirects are mostly 600n (a few 610n) with the latest firmware on
them. We have a few HP 9300's hooked up to external jetdirects and they
are fine.. Its weird because the 2230/2280's will report other issues,
it just seems to be the "status" that is wrong..
For instance we have one right now that say Low Toner - Intervention
Required.
Trying to get help from someone at HP as well.. Almost seems like
however it communicates back (SNMP?) to the server it is passing the
wrong info..
Thanks!
Jeremy
Was this helpful?
Yes
No
Solution #5
Not Rated)
2Pansy
Rank: Apprentice
Rating: 0%, 0 votes
It might not be a bad try to go with HPGATE. I do have a couple of HP
printers that do work a bit better with HPGATE. Generally, though, the
Novell one suffices.
That printer is using an internal JetDirect? If it's an external one,
can you swap it with a printer that doesn't have problems, just as a
test?
Was this helpful?
Yes
No
Solution #6
Not Rated)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the suggestion, but they are already up to date..
Wondering if switching to the HP gateway instead of the Novell gateway
would help. But in watching the forum here, that doesn't seem that good
of an idea..
Was this helpful?
Yes
No
Solution #7
Not Rated)
LiZzIe
Rank: Apprentice
Rating: 0%, 0 votes
Maybe try updating the firmware on the JetDirects?
Was this helpful?
Yes
No
Popular Solutions for HP Business Inkjet 2230
Questions and Unsolved Problems for HP Business Inkjet 2230
Do you recommend HP Business Inkjet 2230 Printer?
Answer
Answer
i have a hp photosmart c3150 printer. I bought a ink pack (combo pack) from the local walmart store.... (More)
Answer
My Fax machine says that its memory is full I have an HP office jet J4500 and I am not receiving any... (More)
Answer
When I try to print a page the printer makes sounds like it wil print a page but does not produce... (More)
Answer
I put new color (cyan, magenta, and yellow) ink cartridges. Since then I cannot get colors correct.... (More)
Answer
printer will display intializing on screen for a few seconds then it automatically shuts off.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
