My set keeps shutting off by itself. This seems to happen sporadically, meaning that I could be watching it for 15 minutes, or 2 hours, and it will shut off. At this point I cannot turn it back on, but usually if I wait a awhile I can then turn it on for a length of time. This has been happening since I moved the set to a different house. I am curious what to do, or what part in the set has gone bad...please advise? Thanks.
  • Nathan OBrien
    Nathan OBrien Feb 23, 2009
    I have been advised by local technicians to let the set die completely before attempting to repair. This seems wrong, couldn't this create more component failures? Also, one suggestion was that possibly the set was staticly shocked while moving the set which potentially fried the power board? Any thoughts?
  • Nathan OBrien
    If it is overheating, what should be repaired, or replaced?
  • 6,784 Answers
Hi, your power board has failed. this is the cause of the repeated power off/on. it will need to be rebuilt or replaced. it will cool of for a min then it is able to restart. this is a sign of over heating that is occurring in the power board. its blown.
Posted on Feb 23, 2009
  • 1 more comment
  • Michael Masters
    Michael Masters Feb 24, 2009
    The board has already met its maker so, i would replace/repair this first. you can do a test on the cooling assembly with a voltage meter to see if the fans are operational. if they are not working, you will have to replace them as well. this will fix the issue.
  • Michael Masters
    The dominate issue here is the power board failure. most defiantly.
  • Michael Masters
    replace the power board and, if necessary, replace the cooling assembly if needed. i would test the integrity of the cooling assembly before you replace it. it may be fine.
    Scholar:
  • 124 Answers
I've had a TV just like that, it was a projection TV too. I had to replace 3 fueses and 2 relays in the TV. It worked great after that. Hope this helps.
Thank you for using Fix Ya!
Have a great one!
  • Frank Simard
    Frank Simard Feb 23, 2009
    Like antiochpc said it could be the Fans or even the Power Board.
    President:
  • 1,314 Answers
It could be overheating; the fans may have stopped working. Or the power board could be failing.
Why does my reciever keep turning off by itself?
try looking into the Timer section on the TV. also on Dish if it is left unattended (like stay on same channel etc) it will go in to sleep mode, U then just hit the Select button.. U can go in the Dish menu and set the Sleep mode (inactivate mode ) to a longer time, I usually set my for 8 hours.
Jul 09, 2014 | DISH Network DVR-625 DTV Receiver /...
Sharp LC-32LE240M automatically shuts down
It should have come with a one year parts and labor warranty so consider looking into getting it fixed under the warranty--opening set or tampering inside would void the warranty.
Dec 19, 2012 | Televison & Video
The hot water recirc pump in my new house was equippped w/ this timer. There was no user manual, but it was set by the installer to run the pump during awake hours and shut it off during sleep hours. ...
1) Open link below so we are talking about same type of household system
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) 15 minute interval is misleading.
Pins located on timer dial divide 24-hour day into 15 minute intervals.
You set timer pins and decide which 15 minute intervals you want ON-or-OFF. Do this by moving pins inward or outward with your thumb or ink pen. To check settings, manually rotate timer dial clockwise and listen for pump turning on-off..
Set timer pins for 4 consecutive 15 minute intervals, then timer runs for 1 hour.
After pins are set, then manually rotate dial to set current time.
Dial rotates as time passes, and pins click a lever that turns pump on-off.
3) 5-year Life span. Like all things plumbing, if you have hard water or sand-n-dirt in water lines, then pipes clog. And pumps clog.
Once motor begins to slow down, it overheats and burns out.
Water softener can keep sediment out of lines, but shortens life of water heater.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
4) Real question: do you need a circulation pump? Do you need hot water at your faucet? Can you schedule hot water use, or does recirculation pump have to run several hours per day?
Recirculation pumps causes water heater to run more, the pump consumes 25+ watts depending on pump, and water savings claims of 15,000 gallons per year are fabrication.
Realistic water savings is 700-2000 gallons per year, assuming several folks in the home use water sporadically across a full day, and each time water is used people are waiting for hot water. It also assumes that you never want cold water at the tap and that refrigeration ice maker line prefers hot water to cold.
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pump/timer or any do-it-yourself project.
We are always less expensive than a service call.
Dec 18, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Heating up, shuts off, Shutting off going about an 1 hour trip. hearing small noise in front of engine. Seams to be running hot. service techs put it on dyna but no results. Shut off again next trip. ran...
Had a simuliar problem, Bike would have a total shutdown a High Temps/Low Speeds/High RPMs. Everything would reset itself after appox 2 minutes. Everything would shutdown Electric and engine.
2 Harley dealers spent 75 hours diagnosing it, dealer could not reproduce it. Last repair was to replace battery cables. Seems to have fixed it. Have ridden 15oo miles since repair. Problem reacurred once last time I rode. Again complete shutdown bike restored after 2 minutes. Did not happen again the rest of the day over 200 miles
Aug 30, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Tv keeps shutting off
Check that you have not set the sleep timer on so that it goes off after 1 hour
Aug 17, 2009 | Televison & Video
Color loss
Your formatter or what is called the FMT board has bad capacitors on it.
May 23, 2008 | Mitsubishi WD73727 73" HDTV
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
