Question about Philips Magnavox Learning Universal Remote
Buttons on television won't work Screen continually displays demonstrations of sleep mode, closed captioning etc I can receive channels but these demos will not go away they are full screen It is hooked through DISH but worked previously
I Have a universal remote and a polaroid lcd and cant change channels- my remote is the old rca
Posted on Feb 24, 2009
Magnavox older tv; suddenly shows a "tutorial" which begins "Here's why this should be your next tv". then reviews tv's features ex: close captioning, sleep timer, language,...
Your TV appears to be in what is known as DEMO MODE, which is used when the TV is set up in the store on display.
In order to disable that mode and return it to normal operation, try the following procedure:
Turn on your TV.
Hold down the VOLUME UP and the VOLUME DOWN buttons at the same time for 10 seconds.
Be sure to use the buttons on the front of the TV and not the ones on the remote control.
Some models may turn off at this point while others may not. Either way, the set should now be ready for use in NORMAL MODE.
If that does not cure the problem, then check in your OWNER'S MNAUAL for the exact procedure on how to disable the demo mode feature.
I hope that was helpful to you, good luck and take care.
Joe.
Jun 20, 2011 | Televison & Video
Magnavox Demo TV
Could you please provide the model number of your TV?
It appears that the TV demo was activated by accident.
Jul 23, 2008 | Philips Magnavox 27MS343S 27" TV
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
My tv is stuck in a closed caption screen
CLOSED CAPTION SELECTION SLEEP 10 To cancel the sleep timer: Press the SLEEP button repeated-ly until "SLEEP 0" is displayed. You may view specially labeled (cc) TV pro-grams, movies, news, prerecorded tapes, etc.with either a dialogue caption or text displayadded to the program.1) Press the MENU button so that the menudisplay appears on the TV screen.2) Press the CH(annel) ▲ or ▼ button to pointto "CAPTION".3) Press the VOL(ume) ▲ or ▼ button to selectthe mode you wish.4) When done, press the MENU button to exit the menu
Then turn OFF.
I also include your user manual below. It's easier to read in there.
www.symphonic.us/pdf/om/ST413C.pdf
Aug 21, 2010 | Symphonic ST413C 13" TV
How do i turn off the subtitles on my toshiba 36hf72 tv, without the remote
The subtitles in dubbed videos VCD/DVD the process to follow are :-
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and
sound effects of TV programs and videos that are closed
captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the
current program, such as weather or stock data (when provided
by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2. Press MENU, and then press x or • until the CUSTOM menu
appears.
3. Press z or y to highlight CC.
4. Press x or • to highlight the desired closed caption mode, as
follows:
• To view captions, highlight C1, C2, C3, or C4 (C1 displays
translation of the primary language in your area).
Note: If the program or video you selected is not closed captioned,
no captions will display on the screen.
• To view text, highlight T1, T2, T3, or T4.
Note: If text is not available in your area, a black rectangle may appear on your screen. If this happens, turn the Closed Caption feature OFF.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Note:
A closed caption signal may not display in the
following situations:
• when a videotape has been dubbed
• when the signal reception is weak
• when the signal reception is nonstandard
PS: If you do not want to set these function & their commands can be entered via the buttons on the TV set. Using the remote is much easier to operate............ sodeep
Oct 08, 2009 | Toshiba 36HF72 36" TV
Black box on screen covering the picture
This is a box for text, such as closed captioning or demonstration mode. Go into your setup menu and turn off closed captioning or return to factory settings.
Jun 28, 2009 | Broksonic Televison & Video
Magnavox TR2510C101
Pressing the volume up and volume
down buttons on the set simultaneously should work.
Good Luck.
Jul 28, 2008 | Philips Magnavox 27MS343S 27" TV
Closed Caption won't turn off
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
Dec 08, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Aug 23, 2007 | iLO 3200 32 in. LCD Television
Philips Magnavox Learning Universal Remote Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
