Question about Motorola Mobility SLVR L7 Cellular Phone
Screen problems i had dropped my motorola slvr l7 in the toliet on accident but i took it out immediately and removed the battery and the sim card. i also cleaned it out by wiping it down then i vaccum the places i can to get the inside and i also cleaned it with alcohol. now the only problem that i have is that the screen is not coming up. the keypad lights up but the screen is still black. any help with trying to fix this. thank you
  • 530 Answers
Hi im josh a mobile phne technician i cebu phils. Friend the problem is your phone is wet til right now im sure. Friend don't use alcohol to clean it will not cure instead it will intensify the problem. As my expertice in phone you need to use a thinner lacquer thinner for appliances and for paint. lacquer thinner is a substance that will dry easily and can enter in any slots of the part to push out the  water that can cause rust. and friend thinner will not leave any mark to make rust so it is the safest one. you try to disassemble your phone remove all plastic parts and  rubber parts coz the thinner may damage it. only the metal parts of the phone you sink it in the thinner for at leat 40 mins. then after mins. remove and let it dry under the sun or under the electric fan. for a long time about an hour or more.,then after you assemble the parts.then it will be back the same as new. don't use the battery it cann't be repaired.  good luck that solution is 90% sure and safe. please vote me so that i will know if i helped you.
Posted on Feb 23, 2009
My phone was working suddenly my motorola was showing insert sim
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.superunlockcodes.com/motorola-l7-slvr/rs12wp9/
Dec 24, 2010 | Motorola Mobility Earwrap Handsfree For...
Motorola insert sim problem
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.theunlockarena.com/motorola-l7-slvr/rs13wp9/
Nov 03, 2010 | Motorola Mobility Earwrap Handsfree For...
Where do I put the sim card in a motorola L7 please let me know. rattler7010@yahoo.com
In the above image i will clearly explain how to place the SIM card.
First please remove the back cover by pressing in outside(side ways)
and remove the battery and place the SIM card in the Gold plating.You have to slide the metal projector and place the Sim card.The RED marking is the place where you place the SIM card.The blue marking is the metal which you have to slide to place the SIM card.It is like a holder to hold the Sim Card
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | Motorola Mobility SLVR L7 Cellular Phone
How to insert a sim card to a motorola L7c model? please help me
Press clip at base of phone, lift off back cover, remove battery, sim card fits under the battery
Oct 04, 2009 | Motorola Mobility SLVR L7 Cellular Phone
L7 Camera is not working.
check any vires issue,or full format
Aug 18, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Phone not reading sim card
dont worry there is some prblm in ur sim pls contact ur customer care there is no prblm in ur phone
Oct 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Broken motorola slvr L7
if you can still go to menu and to the setting' try to master clear and master reset your phone....
i hope it will help your prob.
Feb 23, 2008 | Motorola Mobility SLVR L7 Cellular Phone
I tunes
you may need to do a master reset of the system
Oct 27, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Nothing on the screen
We took out the battery and tried to charge the phone with only the SIM card and it started up for some reason.  This helped for a few days and then went out again.  If you have your emei number on your phone on back of battery, it might be under warranty and you can get it fixed through motorola.
Oct 24, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Phone says "charge complete" but then just dies
I took your suggestion and replaced the SIM card, but the difference is I managed to locked it in tightly. It worked.
Aug 21, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
74 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
