Question about Apple MacBook Pro Notebook
USB flash drive not recognized by Macbook Pro
I bought two 4GB PNY Attache jump drives and, when I plug them into my 2007 MacBook Pro, neither show up in Finder. Strangely, they work just fine in my old 2001 iBook, so I know the problem is with my computer.
Any suggestions?
  • catherine_by Feb 24, 2009
    Thanks for the advice, Josh. I checked my USB connections as you suggested and found that my computer does recognize the flash drive. Unfortunately, I couldn't go much further with your advice as I'm on a Mac, not a PC, and don't have a bios setup utility.
    However, I ran Disk Utility and re-formatted the jump drive from MS-DOS (FAT) to Mac OS Extended (Journaled) and now it works just fine.
  • catherine_by Feb 26, 2009
    Ok, I'm a technology idiot. Since most of the world runs on PCs, my Mac-formatted flash drive is pretty useless.
    If I reformat it back to MS-DOS (FAT), how can I tweak my Macbook's settings to read it? I tried to follow your advice, but Macs don't have a BIOS setup utility.
    Can you please translate your instructions to Mac?
    Thanks!
  • 530 Answers
Hi im josh in cebu phils. if that happened that the usb port don't detect your usb drive then there maybe some problem in your pc. friend all you have to do is check first the usb connections of your pc.you can browse the my computer device manager then click the usb icons and see if marked + or 2nd you reboot your pc then go to bios setup utility then go to peripherals then check wether it is enable.if disable usb on board you enable it. and don't forget to save the changes you made before you exit. then reboot your pc. then problem will be solved. good luck please vote me so that i will know if i helped you.thnks
Posted on Feb 23, 2009
PNY Attache flash drive not being recognized
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Sep 15, 2011 | PNY 4GB Micro Attache USB 2.0 Flash Drive
Just bought a 4gb attache, plugged it into the usb on macbook pro and nothing happens
You can try going to the Disk Utility (which is under Applications > Utilities > Disk Utility), selecting the drive (if it appears) and click "Mount". If it doesn't show up in the Disk utility, then the device may not be connected properly, the USB port may not be functioning, or the device may be malfunctioning. You may try reformatting the drive with the Disk Utility if it is blank and you are just using it for the first time.
Mar 12, 2011 | Apple MacBook Pro Notebook
Windows XP home edition not regonising PNY pendrive micro attache 2G
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
Dec 27, 2010 | PNY 4GB Micro Attache USB 2.0 Flash Drive
Just purchased a pny 4gb fashdrive for a MacBook. It is noy recognized on either USB port
is it compatible to the USB technology ? as in USB 2.0 vs. USB 1.0
try the flash drive on another computer , sometimes if you format the flash drive (Insert into USB connection, right click and press format) -- that may work
let me know please.
Nov 03, 2010 | Apple MacBook Pro Notebook
I have a new PNY 8GB usb flash drive that isn't being recognized by my Macbook pro.
Try renaming the drive letter
Hope it helps
If this helps you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well.
Thank you.
Oct 27, 2010 | Apple MacBook Pro Notebook
Need driver for pny mini attache 2.0
Here are a few possible sources for your driver software :
http://en.kioskea.net/guide/905619-pny-pny-mini-attache-4gb-usb-2-0
www.paretologic.com/lp/drivercure
http://www.helpdrivers.com/ingles/listado/panel.asp?marca=PNY&perif=otros
http://driverscollection.com/?V=PNY&S=48
try these sites they should provide you with success
Jan 04, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
NEED DRIVER FOR PNY 8GB USB ATTACHE
If you're using the drive on a PC with Windows XP or Windows Vista, you don't need a driver - just plug it into the PC and Windows will recognize it and install USB drivers automatically.
Dec 07, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
4GB Attache flash drive says it's locked.
Plug in the stick. wait for it to come up on the desktop then click on it once. (do not open it).
From the file menu select "Get Info"
In the panel that opens up you will see a row of coloured squares. Underneath is a checkbox marked "Locked"
Is it empty or ticked?
If it's ticked, untick and see what happens in disk utility. If it's not ticked that then would appear to be a problem with the stick.
For what it's worth, I did a google on this stick and found that there are numerous posts about it becoming read only on Vista, so it may well be a problem with the manufacturer.
Sep 07, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
PNY Optima Pro Attache 4 G
Make sure you are using the right port. There are slow and faster ports on a laptop.. So try plugging it into another and see if it helps
Jul 18, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Apple MacBook Pro Notebook Logo
12,227 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
