Question about GE JSP34 Electric Kitchen Range
PER5710BAW Broiler element does not work
Baking element works fine, as do all of the stovetop elements. No indications of error codes on the display. Replaced broiler element, still no joy. When broil is selected, one light (broil) comes on, but not the Preheat light. I can hear the relay click for the preheat, but... Nothing. Left it on for an hour, still no heat. Do I need to replace the CLOCK W/OVERLAY unit?
  • johncee53 Feb 24, 2009
    Any other suggestions?
  • 1,800 Answers
Replace the relay.
the problem is related to a defective relay.
Posted on Feb 24, 2009
  • 547 Answers
Replace element please check all fuses before trying to repare here is a site for complete diagram http://www.partstap.com/ thank you for useing fixya please rate me
  • albert getty
    albert getty Feb 24, 2009
    most likley the relay you hear clicking did you here it before?
  • 54 Answers
I recently had this problem with a jenn air stove. Only it was the bake function. The bake element had actually failed and required replacement however, after replacement, it still would not bake. I tried the short cut and replaced the temp switch on hope alone...no joy. Finally, I replaced the clock....it now works like a champ. I was able to save myself $100 by purchasing the part on-line but, I had to go through two of them before I finally got a good unit.
Posted on Feb 23, 2009
  • 6,784 Answers
This is a control panel issue and it will need to be replaced. i would make sure its not a lose connection before i purchase a new one.
    Brigadier General:
  • 8,619 Answers
Hi!
I think either its not wired correctly or the connection of the broil element with the selector switch has broken.
  • Rylee Smith
    Rylee Smith Feb 24, 2009
    Also, check for power coming out of the module/pc board on wire marked "br' when broil is selected. If no power you have a bad broil relay or a disconnection from broil relay.
    Inspect the wires from broil element, and the main terminal block for burnt or loose wires.
  • Rylee Smith
    To repolace the broil relay follow these steps---
    1 - Disconnect power
    2 - Remove the cover panel
    3 - Install new relay on the main back ( don't remove the defective old relay )
    4 - Disconnect wire L2 from the TRO relay and marrette it to the orange wire of the new relay.
    5 - Disconnect wire H1 from the TRO relay and marrette it to the red wire of the new relay.
    6 - Disconnect wire H2 from the TRO relay and marrette it to the black wire of the new relay.
    7 - Reinstall the back panel and reconnect power to the range.
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
My bake or broil will not work but my stovetop works fine, as well as the clock and oven light.
Does the oven indicator light come on when you turn the oven on? Does the baking element or the broil element work by themselves but just don't work together? If nothing at all works did they stop working at the same time? Need to know to troubleshoot. Please reply with more info.
Feb 16, 2011 | Frigidaire FEF336BC Electric Kitchen Range
When I turn my oven on bake the broiler element runs and eventuly the f2 codes comes on.
your oven uses fboth the broiler element and the oven element during baking. Since you know the broiler element works, you most likely will have to replace the oven element.
Oct 01, 2009 | Ovens
Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 25, 2009 | Ovens
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Oven doesn't work but broiler does
I think there is a problem with my top element, it doesn't cycle on when baking. The bottom element works fine. Also, the broiler works. What's the problem?
Apr 29, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE JSP34 Electric Kitchen Range Logo
127 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
