Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Can you convert a 220 dryer element to a 120 ellement
Have purchased a stack spacemaker GE washer & dryer, it is a used one but in very good shape. The problem is we want to put it in an RV which is only 110 electric. Can we change this dryer to a 120 heating element? Right now everything is working but the dryer won't heat.
Model # wsm2420d1ww
    President:
  • GE Master
  • 2,651 Answers
No that machine is wired for a 220v. has 220v components in it. no way to change that sorry
Posted on Feb 23, 2009
I have a GE model# GTUP240EMWW washer/dryer combo. I wired it with the three wire configuration. At first the washer worked but notthe dryer and now neither will work. I checked voltage the breaker, the...
Sounds as if the converter may be bad. The washer needs 120 volts when the dryer 220-2225.The converter determines or supplies which is which.
Jun 17, 2017 | Dryers
Dryer not getting hot
It could be the heating ellement(s)
They can be found by taking the back panel off.
Before doing ANYTHIG unplug the dryer to avoid injury.
Sep 20, 2012 | GE Spacemaker Washer and Dryer Electric...
1989 (?) GE Spacemaker washer in a park model trailer has a cracked plastic air pressure tank. No model # on washer, how do i get parts.
You do need the model number to order parts...typically on a stacked unit the model number is inside the dryer door
Sep 08, 2011 | GE Spacemaker Washer and Dryer Electric...
I bought a used stacked washer /dryer. I hooked it up likea standard 220 dryer. Has the standard dryer plug in. Would not run start or hum in 20 mode. Checked the wiring. looks like it was wired for 110,...
All standard dryer motors run on 120V. Its the heater that uses 240. Its possible to wire a dryer for 120V operation and it will appear to run ok but it won't heat efficiently and it will take several cycles to get the clothes dry. Sounds like you have a mechanical problem with the motor.
Jul 14, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
Are the Kenmore stacked washer/dryer run on 120 or 220?
Models will be manufactured for each. Check the plates on the back; I'm sure it will be marked there, or in your booklet (?).
Cheers,
John C
Mar 03, 2011 | Kenmore 98702 Stacked Washer/Dryer
Dryer runs but does not heat
If the dryer is electric, you most likely have one of two issues going on...
1. An electric dryer uses 240VAC to operate. That's actually two 120 volt circuits wired into the dryer. One circuit runs the drum motor and controls while the other is dedicated to running the heating element. Check both legs of this circuit for blown fuses, etc.
2. The heating element may be worn out. You can check continuity of the element to see if it has an open circuit inside.
If the dryer is gas, there are a number of possibilities... post again if that's the case.
Good luck.
Jan 18, 2011 | GE Spacemaker Washer and Dryer Electric...
GE SPACEMAKER dryer working but blowing cool air. what do i do?
check for proper voltage to the machine should have 220 volts if you only have 110 volts it will run but not heat if you have 220 volts you could have a bad heating element
Nov 18, 2010 | GE Spacemaker Washer and Dryer Electric...
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Does the Maytag LSE7806ACE require a 220 plug?
If you hook it up to 120 volts (by connecting L2[red] to common [white] the dryer will operate, but your heating element will only produce 25% of the heat it would on a 220v circuit. The drying time would be about 3 hours, and the auto dry setting may not work. Heat difference is about 5000 watts of heat on 220v, vs 1250 watts on 120v circuit.
Dec 19, 2007 | Maytag LSE7806A Top Load Stacked...
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
295 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
