Question about Moen 2919 Chateau Two Handle Tub and Shower Faucet With Standard Valve In C
Old Moen Valve Body
HI,
I have a 20 yr old condo that I'm renovating--has old Moen Chateau Valve Bodies- rather than rip up the tile--is there any shower trim that will fit it--not posi-temp.
I heard that Newport Brass would fit it.
Please help
    Problem Solver:
  • 19 Answers
Some will fit but does vary.best bet to find a plumbing supply store such as ferguson,winnelson,or which ever may be by you that has replacement part for older valves or may be able to order. crossing up different makes can be a bit chancey for proper functioning but does work sometimes. not suggested if wanted done right with quality.
Posted on Jul 07, 2009
  • 547 Answers
Take a mesurement of tap head across then go to local hardware store and have a look around it might be better to change hole set . thank you for useing fixya please rate me
Posted on Feb 26, 2009
Can't .find serial number cartridge
Call Moen's customer service help line at 1-800-289-6636
Jul 26, 2014 | Moen Home
My Moen Chateau (older style) kitchen faucet is leaking under the cap that covers a black plastic part where the on/off lever attaches. I purchased and installed a new cartridge, but that didn't
Did you know Moen faucets are warranted for life? You should go to Moen's website to identify the faucet you have and then contact them directly. They will ask you when you purchased and / installed the faucet but will not ask for a receipt or other proof of purchase. If the faucet was installed by a previous owner and registered by them - that warranty will be void unless you installed the same faucet after you bought the home (renovation, etc.).
All parts and tech support are FREE from Moen and if your faucet is being phased out, they will offer you a choice of faucets from their current line up (similar to the one you have) for very short money (I paid less than $50 for mine).
Feb 26, 2013 | Moen Plumbing
How do I remove the cartridge from the Moen shower handle L2353, it is stuck and will not come out.
Sometimes they can be a pain. Here's a video just for kicks, make sure you pulled out the retaining clip:
http://www.youtube.com/watch?v=J-SNBNijfQc
What I have done with them in the past is, I put a block of wood against the tile and put vise grips on the stem, then pry against the wood block, so as not to break or mar the tile.
Good luck,
Dave
Jun 27, 2011 | Moen Chateau, One-Handle Posi-Temp...
How to insert bearing washer on moen single handle kitchen faucet
I have the exact same problem! The gray plastic washer has popped out from between the plate and the brass groove below the washer! I can't for the life of me get it back under there. Because it's sitting too high, the handle doesn't fit and the metal plate is loose.
Please help!
Apr 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
No pressure.. Help
cartridge # 1222,i am not aware of the # for the puller, i just asked for a moen puller.be sure to get one that pull's pos'i cartridge's. because the older type puller will not pull positemp easy.and while you have cart out run water to flush valve body out.good luck!
Feb 01, 2010 | Moen 2352 Chrome Chateau Single Handle...
My shower/bath control just turns and the water the does not turn on.It initially was dripping constantly then stopped working completely. (Moen)
sounds like the cartridge is stripped where it goes into the handle. If it is not coming on at all from either the hot or the cold....I would say there is a blockage inside the valve body.
Oct 21, 2009 | Moen 2919 Chateau Two Handle Tub and...
My Moen Chateau model 2995 shower handle will not work, will not turn to shower postion. Handle seemed to have "frozen up".
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Mar 25, 2009 | Moen 2995 Chateau Three Handle Tub and...
Trying to get the handle off a single handle moen kitchen faucet
Hi adelinette,
Pry the cover off the top of the faucet with a little screwdriver. Under the cover you will find an allen head screw. Sometimes a little upward pressure with a screwdriver will help. Unscrew it and start disassemblying. Pay attention to part location as you take the faucet apart. you will be replacing a stem and not a washer when you get into it.
Good Luck and please rate this response, Phil
Jan 03, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Moen 2919 Chateau Two Handle Tub and...
Moen 2919 Chateau Two Handle Tub and Shower Faucet With Standard Valve In C Logo
292 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
