Question about Frigidaire FD38NGDC Grill
Low flame I have a Frigidaire 4 burner LP gas grill that does not get hot past the low end of the "Grill" meter when all 4 burners are on. When all burner are turned to high you barely see any flame. When I turn on any 1 of the 4 burners you at least see a flame better than before but still not good. The unit is sealed other than looking at the burners. I have tried the following: 1 Looked for a kink in the hose 2 Check the gas tank (put a new one in also) 3 Cleaned the gas lines
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
2 Suggested Answers
  • 7 Answers
SOURCE: Ducane lp gas grill flame pulsates
Have you replaced the battery ? They do rust and lose contact over time outside.
Posted on Apr 17, 2010
Some burners don't work
this is a gas fireplace & everything is on low flame high flame it just won't stay lit
Jul 01, 2012 | Brinkmann Charmglow Stainless Steel LP...
Not enough gas pressure it seems. Grill flames are not going on high. High operates like low.
This sounds like a classic symptom of a bad regulator. Try replacing the regulator and hose.
Jun 19, 2011 | Barbeques Galore Turbo Elite 4-Burner with...
How can i manually ignite the grill
What I do is remove the grates and flame guards and light the burners with a stick lighter then turn em on low and cover them with the flame guards then sit the grates back on there.
May 28, 2011 | Brinkmann Charmglow Stainless Steel LP...
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
Feb 27, 2011 | Brinkmann Charmglow Stainless Steel LP...
Can't operate more than one burner at a time
It could be something very simple. Remove the tank from the unit. Open and close all valves on the unit. Reattach the tank and SLOWLY open the tank just a little bit so as not to trip the safety mechanism inside it. Then retry.
Low flame on Outdoor Gas grill
Sep 29, 2010 | Brinkmann Charmglow Stainless Steel LP...
I am getting very low blue flames, when I light the back or middle burner the flames get smaller and sometimes go out. Grill not getting hot. Could this be the regulator??
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
Aug 23, 2010 | Weber Genesis Silver B Grill
I have a full propane tank. I bbq'd about 3 weeks ago, same full bottle. Grill will not light. Good spark at ignitor. Used lighter and lit for a few seconds with low flame on high. No other burners will...
You may have turned the gas tank valve on too fast. Turn it back off, disconnect it and reconnect it. Then very slowly turn the valve back on. Light one burner at a time and turn to low before lighting the next. If you are hearing and smelling gas with the tank on but all grill knobs off, don't use the grill. You may have a leaking grill valve, regulator or hose. If you are only smelling gas with the knobs on, it's possible you have a clogged burner or orifice from bug nests, spiderwebs, etc and need to clean it out first. Hope this helps. Douglas
Jun 13, 2010 | Brinkmann Charmglow Stainless Steel LP...
Gas grill
Probably 1 of 3 things:
Check your LP tank valve at an LP filling station. Make sure both valve and tank are in working order.
Next check for webs or cocoons up around where knob valves go into burners. You may have to remove burners to see into back of valves. Then swab orifice holes with a torch tip cleaner.
Third, a Menards , LP outfitter/station, or grill shop should have a universal replacement rubber gas line and "regulator"(possibly plugged or stuck shut). Sometimes you end up with cheap/bad regulator out of the factory.
Good luck and hope one these helps or does the trick.
Mar 25, 2009 | Weber Genesis Silver B Grill
Frigidaire FD38NGDC Grill Logo
99 people viewed this question
Top Frigidaire Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Frigidaire Grilling Expert? Answer questions, earn points and help others
