Question about HP Compaq Presario V2000 Notebook
My pc monitor keeps going off and when the computer boots up it beeps and the monitor wont turn on properly . however the monitor works fine when attached to another laptop computer. does this mean the graphics card is faulty. also when I boot up the computer it has a long beep then two shorter ones and the monitor won't turn on. It did worked for a while then suddenly the monitor just goes blank. Help!
  • 2,653 Answers
Yep, problem is with the video card. If it's a desktop you can pull the video card out and install reseat it back into the motherboard to see if that fixes the problem.
Let me know.
Posted on Feb 23, 2009
Soyo sreen is black cannot sinc with my pc
this can be your computer issue not monitor try connect to other monitor and make sure your computer is working fine ,you can check all the lights on the computer are on and getting no beeps sounds usually you will hear a single beep when PC is booting well
Jul 28, 2016 | Soyo Computers & Internet
Computer comes on but will not boot up
There could be number of reasons, usually it could be a hardware failure. first check the monitor if its properly connected. check the fan for the processor it its working. If your hearing beeps surely there is a hardware failure, if its 2 short beeps then there's something wrong with the memory, turn of the computer and check if its properly connected. if the beep is a long one then that's the hardisk turn off the computer if the also properly connected. Another thing if your computer have graphics card try to remove that and connect the monitor to the motheboard's video port which is color blue.
i hope this helps. please rate my solution
Jan 06, 2011 | HP Pavilion xl756 (P1358A#888) PC Desktop
Worked fine last night, discovered it this morning still turned on but no signal to monitor. Rebooted and it began a consistent beeping with no signal to monitor. Unplugged several times to no avail....
the beeping is coming from the cpu.
1 unplug pc
2 pull out ram chips
3 use an eraser to clean the gold, yes thats gold
what happens is the gold on the ram oxidizes and does not connect properly and can go bad but cleaning it with an eraser sometimes works. take a cpu that is working unplu it pull the ram and you will see the same thing your other pc is doing.
4 reinstall ram (correctly)
5 boot up cpu
6 please vote.
Dec 13, 2010 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
The computer does not fully boot when turned on, and the tower makes a continuous beeping sound. The monitor works fine, the problem is the tower. The tower just keeps on beeping without turning on or...
That beep could mean alot of things, but probably a VIDEO CARD or RAM has become unseated.
If you feel comfortable with this, UNPLUG THE COMPUTER take off the case, remove and reinsert the ram chips, and the cards. You might need a screwdriver or two, and a LIGHT. The ram tabs are small.
Good Luck
Nov 25, 2010 | Microsoft Computers & Internet
Was trying to hook up hp printer. when i plugged
HP Printer driver problem. Disconnect Printer and see if the computer boots up properly now.
Mar 09, 2010 | HP Compaq Presario 6320US (DA202A#ABA) PC...
Computer not booting properly.
try taking out one of your ram sticks and boot up.
Mar 03, 2009 | Medion MD1777 (MD1777C67) PC Desktop
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
It wont boot up
The power supply unit is bad. You will have to replace it. Also, it is custom specific ~ write down the specs of the PSU and order it from This recently happened to me.
Oct 12, 2008 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Video card
Working and Working properly are 2 different things.
Unplug your pc. Let it set for 1 minute.
Plug in your pc.
Press the power button.
Does your monitor do anything?
No? Then it doesnt work
Yes? Then it works
If you get any video such as your BIOS or WIndows loading then the video card is fine.
Also, if you boot and you hear noises like:
Long Beep short Beep short Beep short Beep
(Long short short short)
Then your pc is not detecting the video card.
Oct 12, 2007 | Sony VAIO PCV-V210P PC Desktop
HP Compaq Presario V2000 Notebook Logo
59 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
