I get black and gray splotches on all loads, white
I get black and gray splotches on some loads, white and dark.Some splotches are darker than others and they cover all materials.
  • 70 Answers
I would say that the transmission is leaking oil into the load
Posted on Feb 24, 2009
Fixing the picture in my Philips rear projection tv
As far as mostly red--turn color to zero and examine screen--if not gray or black and white it may need the screen controls adjusted.
Dark---with back cover off clean the three lens this model has--they are the light source for your picture and if dusty picture will be darker and somewhat dull looking.
Answer is based on brand/model number listed here.
May 16, 2012 | Philips 50P8341 50" Rear Projection...
Radio was removed from my 91 Seville and replaced with aftermarket CD player radio. I would like to use this radio in my shop. I have 12 DC supply and speakers and antenna. Note: There is no place to plug...
This should be the wire combination for your car: nstant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Speakers
Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Speakers continued
Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Apr 13, 2011 | Car Audio & Video
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
Dark splotch fill the whole paper.
Sounds as if either the drum is not cleaning correctly or has been contaminated.Depending on the model either change the drum cartridge or call out a technician.
May also be a build up of muck on the fuser or the coating ahas been damaged.
Oct 21, 2009 | Xerox Office Equipment & Supplies
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
