Question about Acer Aspire 1800 Notebook
Faded out Acer LCD screen
I have had some issues with my LCD screen & had it replaced about 1 year ago (it went psycodelic). Now the screen is really faded out. I will be sending it back to Acer (thank goodness we bought the extended warranty), but I was wondering if there is a way for me to set the "contrast/brightness"? I am not REAL computer savy, but I can muddle through step by step instructions.
  • dananfitz Feb 23, 2009
    Thanks for the info!! We will pack it up and ship it back ASAP! Glad to know people like you are out there!! You will probably be hearing from me again!!!
To set brightness, try the following.
press the function key (bottom left hand side on your keypad)
then tap the brightness key (just under your numerical keys with a little sun and + mark on it) this should sort your prob
Posted on Aug 16, 2009
    President:
  • 2,653 Answers
It's not a contrast / brightness issue, even at the lowest setting the screen would look normal and probably not the way you're seeing it now. It's likely that the inverter or backlight went out on the lcd. You could possibly turn them up the highest level, but it would still need to be serviced by Acer for it to work correctly.
Glad to hear you've got the extended warranty.
Best of Luck!
Posted on Feb 23, 2009
Acer 4745g black screen problem
So, if you can hear startup sound then motherboard, RAM and HDD is OK! Try to connect it with external monitor, if it's working on it, then problem in LCD, LCD light or LCD cable. If not working with external monitor then it is video card problem, if card is integrated then you need to reball or change at all south bridge on the motherboard, if video is as module card then just replace it with compatible one.
If LCD cable - disassemble laptop to get LCD cable and test each wire with any multimetr with sound beep and replace it if needed.
If LCD light - try to take LCD screen under good lamp then power on laptop and carefully look to dark screen if you see very dark Windows boot screen then you need to disassemble LCD housing, disassemble LCD, remove and replace LCD lamp with working one.
If all this cant help, then you need to replace LCD at all.
Nov 15, 2012 | Computers & Internet
Screen went black! Briefly comes on, very faded, then blacks out again. Haven't had for more than a year...
I've had a similar issue with my Samsung screen awhile back. It should be that your monitor's power supply unit has degraded and needs replacement. You will have to send it to Samsung for repairs.
Mar 04, 2011 | Samsung 933SN Monitor
I saw an answer up above regarding the green hue on the projector, is there anyway to remedy this problem? This is really annoying to me and I would like to fix the issue. Thanks,
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced good_help_9.png
Jan 08, 2011 | Panasonic PT L735U Multimedia Projector
Went dim cant see screen like it was its only one and half years old not even that got it in 2008
This is a power supply inverter issue. Your monitor has a 3 year warranty, you need to contact Acer to have the unit serviced under the warranty plan.
Buddy
Corporate Computer
www.ccl-la.com
Mar 16, 2010 | Acer X193W LCD Monitor
I have two Acer monitors that the on/off keeps flashing and nothing comes up on the screen. I don't think I will buy another one. I tried to save money and have only had these two monitors for less than...
Acer has a 3 year coverage on the LCD Monitors.
I have seen this before the power supply inside the screen has went bad.
I would contact Acer Support 1-800-816-2237.
You will have to pay for shipping just so you know.
I hope this helps please let me know..
- Jon
Aug 22, 2009 | Acer AL1916W 19" LCD Monitor
Sharp wizard oz-290HII --fading screens
Friend, try to replace the battery. If it doesn't work try to press firmly the LCD connection interface underneath the screen because such unit has lossen connection.use T6 screwdriver to open the unit then slowly firmly press the LCD connector on the interface. Such thing will solve the problem. good luck
Jun 16, 2009 | Sharp Wizard OZ-290
Sanyo CLT1554 - faded to black...
This could be something simple or not... How old is the set? Is there any warranty left?
Dan
Apr 17, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Screen issues
take the phone and ahve the lcd replaced...this will correct the issue.
cpatchen, - you need to also have your phone lcd replaced and the main-board service or try changing the battery.
Mar 12, 2008 | Motorola Mobility RAZR V3
Acer LCD fault
Definetly not an inverter issue. you would do well to replace the screen.
Mar 28, 2007 | Acer Aspire 1800 Notebook
Faded screen with lines across screen
hi Jenredd, i think there is something wrong with ccd, if so it is serious... . I experienced some disturbed picture on lcd or whole black lcd due to ccd problem. As u said you pictures are fadded it means may be ccd is damaged. If so you have to replace the ccd at any authorised repairer for fuji. as you mentioned other problem there is nothing common between both. for that i suppose there is some problem in either usb socket or cord , so first check the cord, if it is ok then we can doubt on usb socket. But in both the way you have to go to Fuji . good luck
Aug 01, 2006 | Fuji FinePix A345 Digital Camera
Acer Aspire 1800 Notebook Logo
170 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
