Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
How do you reset the calculator? - Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
  • 35 Answers
Its in the MEM menu... Clears RAM
Posted on Feb 24, 2009
Ti-36x Solar Scientific Calculator issue: number buttons resetting to zero...
Look in the back of the calculator, some TI models have a pin hole to hard reset the calculator.
Mar 22, 2015 | Texas Instruments - Ti-36x Solar...
How to reset calculator
Dear
generally the calculator auto reset but some manufacturer provide a reset switch, its found at back side of the calculator by noticing a pin hole and either embossed or engraved RESET.
But i may suggest to recheck the battery contact points and orientation.
Thanks.
Jan 05, 2015 | Office Equipment & Supplies
Reset HP 17b11+
According to the manual:
To reset the calculator, hold down [CLR] while pressing the third menu key from the left. Repeat if necessary. The calculator displays
MACHINE RESET to confirm that reset has occurred.
The above sequence does not clear all memory and settings.
If you want to completely erase the continuous memory and return to default settings, press and hold down [CLR], the leftmost
menu key, and the rightmost menu key.(Press three keys simultaneously).
When the three keys are released, the calculator displays MEMORY LOST.
Apr 16, 2014 | HP 17bII+ Calculator
How do you reset sharp EL-531XH calculator
There's a small hole in the back marked "RESET." Poke a straightened paper clip or similar implement into the hole.
Aug 04, 2013 | Sharp El-531x Scientific Calculator Green...
How to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
How can I reset the calculator every time before useing it?
There are numerous procedures to reset calculations, worksheets, etc. but the most general one is to press [2nd][Reset][ENTER].
You can also perform a hard reset by pressing the Reset button in back of the calculator.
Removing the batteries has the same effect as the hard reset.
Feb 22, 2010 | Texas Instruments BA II PLUS Financial...
Okay, so I've got a fx-7400G PLUS. My stupid friend put the contrast to light and turn it off. The calculator stop working. What can I do to make it work again? Thanks in advance.
Reset the calculator. On the back of the calculator there is a reset button (Above battery compartment and to the left. Use a thin pointed object to push it. The calculator will ask for confirmation to reset all memory back to default. Press [F1] to accept.
And next time avoid hanging out with stupid people, and don't lend them your calculator. Didn't you know that stupidity is contagious?
Hope that helps.
Thank you using FixYa and for rating this solution.
Dec 03, 2009 | Casio FX-7400G Plus Calculator
Why am I getting error 14 with all the functions under the stat button on my ti-86 calculator? I know I'm entering the right information, but it won't work...
The software for your calculator may need to be updated. You can get the update from the manufacture's website under the download or support tab.
Nov 16, 2009 | Texas Instruments TI-86 Calculator
HP 12C
gtabblt.gif Description gtabblt.gif Resetting the calculator using the keyboard gtabblt.gif Resetting to drain the capacitor gtabblt.gif Other solutions gtabseps.gif Description Sometimes a calculator will lock up or will not respond correctly. The calculator may require a reset for a variety of reasons. These resets will erase the memory on the calculator and restore the calculator’s defaults. For this reason, it is important to back up any critical data. Resetting the calculator using the keyboard The easiest reset is done from the keyboard. To reset the calculator, follow the procedures below in the order presented.
  1. Press ON to turn off the calculator.
  2. Press and hold [ - ] .
  3. Press and release ON .
  4. Release [ - ] .
  5. The screen will display “ Pr Error
  6. The calculator will reset to the default settings, and the memory will be erased.
If the above reset did not restore the calculator to normal, continue to the next section.
Sep 04, 2008 | HP 12c Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
292 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
