Question about Kenmore 46462 Front Load Washer
Kenmore Washing Machine - no cold water coming in
Our Kenmore washing machine model 110 20622 990 top load washing machine doesn't have cold water going into it. All is fine wth lines going to washer but when warm or cold cycle used - no cold water comes into tub. Also snce it only rinses in cold, it won't rinse the clothes but runs through the full cycle. What part is causing this? Solonoid? Water inlet valve?
  • Sam Shamblin May 11, 2010
    It could be one of two problems. Either your water inlet valve which is a single part that controls both hot and cold water with two separate solenoids has failed...(it'll cost you $12 plus shipping if you order it online) or the temp control circuit board has failed....(it'll cost you $30 plus shipping if you order it online) I'm betting the water control valve is the culprit.
  • Anonymous Mar 18, 2014
    kenmore model 82870820 drips cold water in to the tub when off
  • 70 Answers
Most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
Why is my Kenmore elite three speed top loader washing maching model number 110.23022101 only washing on HOT water? The cold will not work. We recently had workers remodeling that room and the washing...
Make sure the cold water supply is on and not blocked.
If the machine fills but does not wash try to find a thermal switch that is supposed to come on when the cold water has heated up.
Jul 20, 2014 | Kenmore Washing Machines
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
My hot water works fine. The cold water only drips in. I took off my cold water line and cleaned the filter. Still only drips. Any advice would be helpful. Thank you.
You will need to replace the water inlet valve. If you could post your model number I will be able to direct you to the part you need.
Jan 06, 2011 | Kenmore 24032\24036 Top Load Washer
Cold water comes out very slowly whereas hot or warm is normal
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 27, 2010 | Kenmore 12502 Top Load Washer
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
The machine will not fill on cold water cycle( only trickles in)
heatman101
Sep 16, 2010 | Kenmore 24032\24036 Top Load Washer
We have a kenmiore top loading washing machine model 27492600 and the cold water only dribbles into the machine but the hot water pours in. how do I access the machine to se if there is something in the...
It is probably the inlet screen on the back of the washer where the inlet hose attaches, is plugged or the cold water inlet solenoid valve nees replacing. Best off to call a reliable service company such as Sears.
Feb 01, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 46462 Front Load Washer Logo
1,618 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
