Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The door starts to go down but comes up like there is something in the way but there is nothing in the way
  • Chuck May 11, 2010
    there is something holding it up or make sure that the pressure is not too soft. there is a little screwdriver adjustment on motor there are actually 2 of them one is for upward force the other for downward force. turn up the downward force just alittle. dont turn up too much just in case if you or a child get stuck under the door while it is closing....hahaha. no serious try this and see if this helps
  • 118 Answers
Check your safety eyes. There should be a light on on each eye. If not, align the eyes so that they are pointing directly at each other. If you adjust force settings like mentioned above, do not go above 6 or you can easily damage the door if there is a problem.
Posted on Feb 26, 2009
When closing door with remote or the electric mounted pad it goes down about 6" then stops and goes back up 2" and then I have to hand wind it back down. fitted 2 years ago no problems until now
Greetings,
There is something blocking the door from closing. Look around to make sure there is nothing near it or touching it.
Once I had a rolledup screen that started to interfere with the closing. Keep all things clear from it.
Apr 14, 2015 | Building Materials
My 2012 ford escape will not start nothing is working my battery is good. cannot open the door with the remote starter
Maybe the battery WAS good. If nothing is working the battery is the first place to look. When you open the door do the inside lights come on? Will the radio play with the key in Accessory position. Something could have ran the battery down and now it needs to be recharged.
Sep 28, 2014 | 2012 Ford Escape
SOMETHING WRONG...
sounds like a vent door selenoid, a frayed wire to the selenoid. The selenoid operates the vent door to close, or allow outside air into car
Aug 11, 2014 | Cars & Trucks
Popping sound on opening Bosch dishwasher door
I just went to look at my Bosch and there really is nothing it can catch on if your kick plate is on correctly. I would feel around and make sure nothing has gotten under there like a piece of silverware. When pulling the dor down as it gets closer to the kick plate you should be able to see the kick plate start to angle back. The only other place I saw that could allow a problem is the openings for the stops on each side (Chrome pieces that are exposed as you lower the door on each side - inside, lower corners) ... maybe something got in there and is binding it up. You may have to get a professional or a handy friend out to look at it.
Dec 08, 2013 | Bosch Dishwashers
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
Liftmaster Professional 1/2 horse model # 41A5483 installed in 02 Learn light flashes 4 times. When openers are hit in cars (2 Chrysler vans use built in Homelink Systems built into sun visors, one car...
check the settings on the unit itself sometimes if you have it set up to come down too rapidly it will cause it stop and go back up because it thinks its hit something.
Apr 10, 2011 | liftmaster Garage Door 1/2 Hp
Garage door goes up fine but when you press to come down it goes down one foot, seems like it hits something and returns.
There is a sensor which checks for obstructions, are you sure there is nothing impeding drive path?Inspect the drive path carefully. If it reaches a part of the drive path which causes it to slip or stick slightly this will tell it not to continue. Also but less likely have you checked that the optical sensor is clean and aligned. Make sure there is nothing blocking the optics.
Jan 17, 2011 | liftmaster Garage Door 1/2 Hp
I have an old Kenmore garage door opener. The door will not go down. It acts like something is in the way of the electronic stoppers, but there is nothing in the way. Any ideas.???
Make sure the door sensor are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Water in tub and nothing happen when we try to wash cloths
usually this is indicitive of a bad pump or something stuck in it.these machines when first started they try to pump out first
the cycle will continue as long as it senses water
have them inspect the pump
good luck with sear service i hope it goes well
Oct 13, 2009 | GE WBVH6240F Front Load Washer
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
70 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
