Question about Weather King 10AJA6001AH Air Conditioner
2 TON WEATHERKING HEAT PUMP VIBRATION AND NOISE.
ONE YEARS AGO WE INSTALLED A 2TON 10 SEER WEATHERKING HEAT PUMP... this past summer I had to replace the compressor????? I know the charge was correct. How ever I noticed the compressor did not have a heater. Thinking this was the reason the compressor failed I installed a band type heater on my newly installed compressor. A friend of mine is stating I should have traps on the suction line.I have approx 20' of vertical rise total length no more then 60' .After approx. 10 to 15mins of operation the indoor and outdoor unit begins to vibrate along with a loud noise..... Help
    Scholar:
  • 144 Answers
Your friend is correct. Installing a sump or p-trap in the suction line will probably help. The oil may be leaving the compressor but can't get back.
Posted on Feb 24, 2009
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The condenser was installed about 14 years ago and it's rated as a 10 SEER. Is there a problem of them operating...
The air 'handler' is nothing more than a type of fan turned by a motor.
The condenser however is a sealed, closed system with coolant that will need to be properly removed (EPA stuff). The condenser must be installed with care, recharged, then checked for leaks.
There is far more involved than replacing an air mover.
I do most of my repairs myself but sealed systems that must be charged is something I leave up to a pro.
Feb 14, 2015 | Goodman Heating & Cooling
What is the problem with running a 10 SEER condenser with a 13 SEER air handler other than efficiency? I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The...
as most ac units are capillary tube control not tx valve having matched units is critical. as for cost the condensing unit is much more complex and expensive than the evaporator.
Feb 14, 2015 | Amana Goodman R-410A Heat Pump Condenser 2...
I need the low voltage wiring diagram for this condenser model 10pjb24a01 weather king
That 10 seer heat pump is typically wired.
http://rheemote.net/docstore/webdocs/Public/ServicePublic/Trouble2/pdfs/Wiring/90-21779-08-06_HP_Typical.pdf
These were typically installed as the cheapest thing available to a homebuilder, mainly installed in rentals and affordable housing. Naturally, they cost the most to run. A higher efficiency unit will pay for itself in a couple of years and then save money every time it runs after that. Of course, replacement parts are inexpensive, so this is ideal for a rental property.
Jan 12, 2015 | Protech Rheem Ruud Weatherking Factory OEM...
Heat pump manual
it is a 5 ton 10seer unit. the new standard is at least 14 seer so there are better options out there
Feb 05, 2014 | Weather King Heating & Cooling
Where can I find the specs for an earlier Goodman heat pump?
You say 2 to 3 years... I'm assuming the unit is older than that. Especially being r22. What about the first 10 years??? Normally you will get 400 to 500 sqft per ton of cooling, but, that depends on heat load calculations. If the unit wasn't big enough you would have had this issue 10 years ago, not when the system kept running low on refrigerant. At first guess I would say a 2 ton unit is not big enough but if it worked fine for 10 years...wuth all that in mind, if it were me, (a seasoned professional) I would spend 1800 to fix my 15 year old r22 unit before I spent $4000 on a new r410a piece of junk. Best Wishes!!
Jun 29, 2017 | Goodman GMS90703BXA Heater
RUUD 14 seer heat pump makes loud squeeking noise after cycling.
Your problem is the TXV. I just had person with the same problem. Replace TXV no problem Rusty
May 01, 2009 | Ruud UAMB Air Conditioner
Weather King 10AJA6001AH Air Conditioner Logo
334 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
