Question about Fedders AED24E7F Wall/Window Air Conditioner
New electrical wiring for split ac
I like to know electrical wiring for split ac
  • Perry Putnam
    Perry Putnam May 11, 2010
    The wiring for which part, the inside, outside or T-stat?
I have asplit air condition and i wont to select the circiut breaker for the condition which is the 6000 unit
Posted on May 02, 2009
  • 306 Answers
Connect the two wire from the t-stat to the coil on condenser and take the 240 volt and connect it to the contactor.
Posted on Feb 27, 2009
Maytag Epic has a damaged wire harness connection to the touchpad assembly.
To prevent any other new electrical problems, it would be better to buy a new ribbon cable.
May 16, 2014 | Washing Machines
F8 dispaly error in blue star split ac
hello,
i also find this problem in my bluestar ac then i callled authorized service man . then he did these steps :-
1> Replace the sensore ( you will find inside the ac wich will be red or brown in color)
2> then check wheather the wire is in good condition or not means
is it working or not.
3> then clean the outdoor unit filters and coils,
4> and check the proper supply of electricity..
Mar 15, 2013 | LG LS-L1210CL Mini Split Air Conditioner
Im replacing the pickups and i want to know what wires go where? theres like two wires connected right now but the new pickup has four.....schematic?
The company from where you got the pickups would have the schematic. What pickup are they.
When there are 4 wires it usually to split the coils in the individual pickups
Dec 14, 2010 | Epiphone Les Paul 100 Electric Guitar
Wiring standard for Split AC 1.5 Ton
The factor that you have not included here is the distance from the power panel to the unit...if it is too far then you need to up gauge the wire to compensate for that... that could be why the electrician wanted to go to the 720 ga. wire.
heatman101
Apr 16, 2010 | Samsung AS18A6RB Air Conditioner
I has a split AC there is problem of electrical wiring between compressor and in house machine. I need some service center address in Ahmedabad city Gujarat to recify the same. My model No. is SAP-K184ML
hi,there is a problem commucating...possible one of the wires has gone bad....you will need to to turn off all power to both units at the breaker at the panel or disconnect...you will need to go to walmart purchase a electronic test meter..they have one for 20.00 ..i bought one yesterday...yiu will need to remove one wire at a time from the indoor unit...get a piece of paper befor removing any wires...mARK NUMBERS....
Mar 26, 2010 | Sanyo Split System Air Conditioner
Hello im trying to trouble shoot two split systems the electrical wires were crossed for the two units I fixed it the compressors wont come on, wall unit says e7? This is on the Amcoraire ac split systems.
E7 indicates an "External Feedback Problem" which sounds like a communication problem. I believe there is a sensor cable that runs from the outdoor unit to the indoor unit also. Check that all cables are properly run to the appropriate unit and check all connections for tightness. Here is the link to a manual that includes installation and wiring instructions.
http://www.acwholesalers.com/EasyEditor/assets/amcor%20duo%20uchw-h12%20owners%20manual.pdf
Mar 16, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
ELECTRICAL INSTALATION OF MINI SPLIT AC MODEL AS18CDB
YOU CHECK THE ELECTRIC SCHEMATIC YOU FIND WIRING GOES FROM INDOOR UNIT TO OUTDOOR UNIT MAY 4 OR 3 WIRES SIZE 2.5MM
Aug 22, 2009 | Heating & Cooling
My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
May 11, 2009 | Carrier 38CKC036 Air Conditioner
Fedders AED24E7F Wall/Window Air Conditioner Logo
296 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Tony Pez
Level 1 Expert
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
