Question about Magic Chef CER1115AA Electric Kitchen Range
THE LIGTH INDICATOR IS ON ALWAYS, NO THE OVEN LIGTH. EVEN WHEN EVERY THING IS OFF AND COLD.
    President:
  • Magic Chef Master
  • 2,651 Answers
Ifthe "hot surface" indicater light is on, its as ighn that the coresponding element is bad( actually only a safety switch within the sensor, but the entire element needs replacing).. hopefully on oyour unit there a 4 indicators one for each burner(helps to see which burner is bad)
Posted on Feb 23, 2009
My Solis crema sl-70. As soon as I switch the main switch on the indicator ligth for water ready to start the pump is always on but the water is cold
Hi
The first thing you should do is turn on the power, then the steam switch and see if you get any heat. If you do, then your brew thermostat is bad and needs to be replaced. If you still don't get any heat, there are a couple of things that might be wrong. 1. Your heating element might be bad. Check it with an ohms meter. The terminals should read 12 to 16 ohms. If no reading, replace the boiler. If the boiler is good then the center thermostat is bad. Its a 138C thermostat. The thermostat in the back is a 92C brew thermostat. The front one is a steam 127C and the one on the left side is a 156 high limit thermostat. The center thermostat is a screw in thermostat and holds the others in. Take a picture of the wiring before disassembly. To get the top off there is a screw in the top center back. Remove, then put your hands on the top side of the machine and with your fingers push the top forward.
Aug 14, 2011 | Solis Crema SL-70 Espresso Machine
I can't get the stove to heat up! The pilot light is on and the burners all work
check the bottom pilot ligth in the boril at the back to the top that poilt ligth it for the ovens
Oct 18, 2010 | Ovens
I just recently bought a house with a Tappan Gas Stove model TGF657 and I am having problems lighting the oven. I have never used or seen a gas stove before.
will be very careful went lighting the poilt ligth.ok make sure the gas it on and the knob on the sotve is off raise the hood you should see the poilt ligth between the burners ligth it with a matche in each one go to the bottom open the door there a poitl ligth at the back to the top ligth it
Oct 17, 2010 | Tappan TGF657 Gas Kitchen Range
I sent my honda accord 1993 to honda dealer/repairer to get check why check engine ligths come ON.they said faulty collant sensor/is this serious problem?and why if the check engine ligths comes on,my car...
a bad coolant sensor not a serious problem that can cause engine damage. but it will make it run real bad ,use alot of fuel ,hard start,ruin your cat converter,etc.they arent that expensive and are easy to put in.
think of your coolant sensor like your choke.it tells the computer how warm/cold the engine is and then compuer when it thinks cold gives more gas or hot and gives less gas.if comuter dont know temp of engine it has to guess and they are always wrong.
coolant sensor bad computer has no way of knowing engine temp
Mar 21, 2010 | Honda Accord Cars & Trucks
The brigth of the rigth head ligth is dimished
you mat have a shorted bulb try changing the bulb if that doesnt work you probably have a bad ground
Feb 06, 2010 | 2003 Suzuki Grand Vitara
I hVE ligth bulb that broke off in the oven how
I usualy use needle-nose plyers, but have herd that you can use a potato to shove it in the socket and turn the broken bulb end out. Make sure you unplug the machin first.
Jan 11, 2010 | Ovens
Powering problem
yes i would say power is bad and maby battery best to buy both before going to replace mobo maby cooling dock they sell on ebay wont hurt ya ether
Jan 05, 2008 | Toshiba Satellite A105-S4004 Notebook
Magic Chef CER1115AA Electric Kitchen Range Logo
111 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
