Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Washing machine does not spin
My washing Bosch Excell 1400 Express does not fully spin anymore. Worked fine then stops spinning.Will start to spin at 11mins, then goes to full spin for about 20secs then stops and the time goes from 10-1 min. All the water has drained away though. Even if you move the dial to spin only it still does not fully spin.Have tried it empty but no luck.
Any answers please?
  • wayne_brisk1 Feb 24, 2009
    It will not spin with clothes in, same problem
  • Bosch Master
  • 744 Answers
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
This new model detects how much loaded it is. they perform the spin according to the charge. If you tried it empty wont spin much. Do a full charge and you will see
Posted on Feb 23, 2009
My Bosch Excel 7 1400 express won't spin heavy bathmats with the result of me having to let them drip for a couple of days to lighten the weight! very inconvenient! have tried redistributing but doesnt...
Heavy Mats, Coats, Bedspreads etc....Your balance sensor will shut it down as you have heavy mats full of water they are very heavy. If it didn't your machine would self-destruct. You might try a commercial laundry as their machines are designed (bolted to the floor) to handle various heavier loads. Even those will shut down if it senses to heavy of a load though.
Hope I helped
Jan 09, 2018 | Bosch Washing Machines
Bosch classixx 1400 express
have you cleared the filter
Feb 03, 2014 | Washing Machines
Bosch Classixx 1400 Express: stopped midway through wash cycle, making a high-pitched beeping noise. Water and clothes are trapped in the machine. I have tried setting it to drain and spin - just makes a...
if there is still water in drum the door wont open try tilting the machine back so the water is not touching the door and wait for a click that normly works
Mar 28, 2011 | Bosch Washing Machines
Bosch excell 1400 won't drain although the pump is spinning. took all the pipes off before and after the pump cleaned them, drained a couple of times then stopped manually drained it witnessed the pump...
If you are certain that there is no blockage or restriction anywhere and the filter is clear, then I would suggest you replace the pump to solve the problem.
They can work intermittently sometimes,due to wear on the pump impellor.
Jan 30, 2011 | Bosch Exxcel WFO 2465 Front Load Washer
Bosch classixx 1400 express spin vibration problems - when my machine spins is vibrate violently and moves across the floor - how do i fix it?
Is the clothing distributer evenly around the drum or is the washed bunching it up and spinning it around as a ball.
Jan 16, 2011 | Washing Machines
Bosch Excell washing machine programme fault
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 28, 2009 | Bosch Washing Machines
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
My Bosch Exxcel 1400S Express (WFX148SGB) just doesn't spin anymore. Everything else seems to work fine?
Bummers. Sounds like the clutch is out. (If you can hear the motor spinning but not the drum, I'd say that's it. Especially if the machine has a number of years on it.)
I once looked into having a service man come fix a clutch. He said it would be cheaper to buy and new washing machine and have the old one hauled away.
Good luck.
Nov 12, 2008 | Bosch Washing Machines
BOSCH 1400 excell
find the punch hole on plate use pointed object stick in hole and turn
Oct 05, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
683 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
