Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How to replace the ink cartridge on cx7400
It's not readily obvious where the ink cartridge is on cx7400. How do I replace a color?
    Sergeant:
    Champion:
  • 237 Answers
Lift up the scanner bed. And its underneath there
Posted on Feb 23, 2009
Clean printheads
The cartridge and or the nozzles are clogged. This is common with ink jet printers.
Jerry G.
Sep 08, 2012 | Epson Stylus CX7400 AllinOne InkJet...
I replaced all of the cartridges with Epson, but the black won't print. After some nozzle checks, black is getting low and STILL no black printing occurring... what going on? Now the other colors are...
Nozzle cleaning uses a lot of ink, that's probably why the other ink cartridges are registering low on ink. Are you using refilled cartridges or brand new? Also, have you had the cartridges for awhile? I've found that the nozzles can become clogged either from not using the printer for awhile or because it's a recycled cartridge that didn't have the nozzles cleaned before it was refilled. When that happens, unfortunately, sometimes it takes a lot of cleaning cycles before the printing comes back. Let me know more about the cartridges you have.
Mar 03, 2011 | Epson Stylus CX7400 AllinOne InkJet...
I need to restore the software for my Epson Stylus CX7000f PRINTER in my new computer. I can not find the original disk, from where can download the software
The Epson Stylus CX7400 Color All-in-One printer prints up to 28 pages per minute of black ... Stylus CX7400 ink jet all-in-one, 69 black ink cartridge (T069120), ... Best of all, you don't need to wait for an available computer to get started. .... Also, given my experience, one paper jam can cause your printer to ...
www.amazon.com/Epson-Stylus-CX7400-Printer.../B000SDXZX8
Jul 16, 2010 | Epson Stylus CX7400 AllinOne InkJet...
I have an CX7400 epson printer. I want to change my ink cartridges but the cartridge doesn't line up with the opening. I can't get to the entire cartridge.
Here is the Quick Reference guide for the Epson CX7400 printer:
http://files.support.epson.com/pdf/cx74__/cx74__qr.pdf
In this guide, under Bookmarks (in Adobe Reader), select Maintaining Your All-in-One, then select Replacing Ink Cartridges. Follow the instructions from there.
Jun 25, 2010 | Office Equipment & Supplies
My brother printer not working well
Are you using Genunine Cartridges!!!!
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 03, 2010 | Brother MFC-5840CN All-In-One InkJet...
Have not used my epson cx7400 printer in months and the printer head is probably clogged up. Tried installing ink but did not fix problem
Here is a Link that would help you. You can also download the manual if you need. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQs&oid=89902&prodoid=63069503&category=Products If you find this helpful, pls rate me. How long should an ink cartridge remain in the printer? When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head. I know you said you changed the ink, but you must use Genuine Epson Cartridges. Epson Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can MAKE YOU & keep selling the ink cartridges.
Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it. Gets costly.
Jan 23, 2010 | Epson Office Equipment & Supplies
I get an error message after replacing the ink cartridge
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. All Generic Cartridges, will print lines thru the words, and also do a mix match with the colors. That's what the These Companies do., so they can keep selling the ink cartridges.
So I learned, thru trial and error, that you must use the ORIGINAL Cartridges for these Printers.
Since you do not mention what type of printer error you are getting, that is the only advice I can give you.
Good Luck :0)
If you find this information helpful, pls rate me.
Dec 30, 2009 | Epson Stylus NX400 InkJet Printer
EPSON Stylus CX7400 won't accept ink cartridge
Mine acts up this same way (more often than not). I've found that as I install new cartridges, it helps to "tilt" it towards the chip end so that it "rubs" as it's going in. You'd normally hold both sides when replacing a cartridge but I don't even touch the outer end as I do it & it seems to help the printer "see" the replacement when installed.
Oct 20, 2009 | Epson Office Equipment & Supplies
Cannot print black on epson cx7400, I bought new cartridges for all four color, but still it doesn't print black, but it is printing all other colors. can some one can help me out?
I've had nothing but problems with Epson cartridges and drying up of ink. If the cartridge is a little old, say a few months, then don't be surprised if its dried up. especialy if its in warmer weather near a window.
If its new, then make sure that the tape is remved from the cartridge [obvious but I thought I'd mention it].
Also, its expensive, but you shodu lonly use genuine Epson ink cartirdiges adn not genreic brands or refills.. having spent coutless hours reparing ruined printers because someone thought they could save a few bucks.. it ain't worth it in the long run.. buy the genuine ink adn use good quality paper..
Jun 06, 2009 | Epson Office Equipment & Supplies
Epson Stylus CX7400 Ink Light Problem
You need to open up the maintenance window and go thru the motions that you are changing the cartridges and this resets the ink levels back to full and sends data to the printer saying that they are full and the ink light disappears and it prints fine !!!
Just changing them doesn't seem to do the trick like on a lot of printers
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
771 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
