Question about Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner
Outside air intake has to be unplugged for it to run? Why is this?
  • 70 Answers
Is the air intake blocked or is it possible the unit is getting exhaust in the intake
Posted on Feb 24, 2009
Ambient outside air temp sensor
i may be wrong but that sensor is for the ac not for engine operation and at 113 if its not that hot then the sensor is bad but if its summer its ok,, your engine works with intake air temp
Nov 25, 2013 | 1996 Jeep Cherokee
Tip
Tips for operating Air conditioning system on Toyota Hilux and someother...
To cool off your Toyota after it has been parked in the hot sun, drive with the windows open for a few minutes. This vents the hot air, allowing the air conditioning to cool the interior more quickly.
Make sure the air intake grilles in front of the windshield are not blocked (by leaves or snow, for example).
On humid, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
Keep the area under the front seats clear to allow air to circulate throughout the vehicle.
On cold days, set the fan speed to high for a minute to help clear the intake ducts of snow or moisture. This can reduce the amount of fogging on the windows.
When driving on dusty roads, close all windows. If dust thrown up b the vehicle is still drawn into the vehicle after closing the windows, it is recommended that the in intake be set to FRESH and the fan speed to any setting except "OFF".
If following another vehicle on a dusty road, or driving in windy and dusty conditions, it is recommended that the air intake be temporarily set to RECIRCULATE, which will close off the outside passage and prevent outside air and dust from entering the vehicle interior.
HEATING
For best results, set controls to;
Fan speed ---- Any setting except "OFF"
Temperature----Towards WARM (red zone)
Air intake ---- FRESH (outside air)
Air flow ---- FLOOR
Air conditioning ---- OFF
For quick heating, select recirculated air for a few minutes. To keep the windows from fogging, select fresh after the vehicle has been warmed.
Press the "A/C" button on for dehumidified heating.
Choose floor/windshield air flow to heat the voltage interior while defrosting or defogging the windshield.
AIR CONDITIONING
Fan speed --- Any setting except 'OFF"
Temperature --- Towards COLD (blue zone)
Air intake --- (outside air)
Air flow --- PANEL
Air conditioning --- ON
For quick cooling, move the air intake selector to recirculate for a few minutes.
VENTILATION
Air flow --- PANEL
DEFOGGING
The inside of the windshield
For best results, set controls to:
Temperature --- Towards WARM (red zone) to heat; COLD (blue zone) to cool
Air intake --- FRESH (outside air)
Air flow --- WINDSHIELD
The outside of the windshield
Air conditioning --- OFF
On humid days, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
DEFROSTING
To heat the vehicle interior while defrosting the windshield, choose floor/windshield air flow.
on Feb 14, 2011 | Toyota Pickup Cars & Trucks
Vokera mynute 28 se, plumber has replaced fan and swithch as the burner would not cut in, was beeter for a year or so, in trying to find the problem again, he has discovered that if the front plate closing...
It sounds to me like the outside air intake (your boiler requires outside air for combustion) is plugged. Bird's nest, maybe? Leaves? Spider webs? Have the plumber check outside AND where the intake air connects to the boiler.
Nov 05, 2013 | Water Heaters
The unit frosts and freezes up after only a few minutes of running...why???
Common causes of this problem are:
1., Dirty or clogged air intake filter.
2. The humidity level outside is extremely high.
3. The compressor is low on refrigerant gas and needs to be recharged.
4. The cooling coils are dirty and need to be cleaned, as do the fins
5. Defrost sensor has failed and needs to be replaced.
Allow the unit to completely thaw and unplug it, before attempting any of the above service work.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 10, 2011 | Heating & Cooling
How to clean the intake filter
I clean mine like this, unplug the fan and head outside, I use compressed air and a blow gun. I blow the air thru the intake and then backwards thru the front heating elements and repeat until you have clean air in both directions. I average about five times both directions and I am good for the year. I have made a practice of cleaning it out in the fall of each year.
Dec 26, 2010 | Lasko 5132 Ceramic Compact Heater
COULD THE AIR INTAKE CENSOR KEEP MY CAR FROM SATARTING
No The air temp sensor will not keep it from starting, if its bad or even unplugged the computer will see it as 32 degrees and all it will do is command more fuel (rich) to help start thinking its cold outside. even with this being the case it will still start, might not idle or run great but it will run...
Oct 14, 2010 | 1996 Buick Skylark
Air intake via hose & window or intake from room only?
Hello artrey3 The answer is yes, BUT the unit will be exausting room/basement air outside ruining any efficency the unit is rated for.Also you will need makeup/fresh air in the basement. The unit exausting air can put the basement in a vacuum/negitive pressure pulling in air from the chimney!
Jul 09, 2010 | Amana Heating & Cooling
Does the air intake pipe for a Goodman heater need to run outside
no both to go outside if you had fumes problem you would have fumes inside your house just example but the answer is no
Apr 10, 2010 | Goodman GMS90703BXA Heater
I have a Coleman TG9S Furnance and I noticed that
Hi there should be a fresh air pipe to your basement from outside to bring fresh air in normaly its behind the unit just above the floor , the air intake is taken from the basement as the air from the intake would now be warm to use , does this help you ?
Feb 09, 2010 | Heating & Cooling
Chemicals in house from pool when running air conditioner
There is a small possibility that the air conditioner is sucking some of the air outside. If you're using a window type a/c, there is a small fresh air intake vent you can open and close. If your using a wall type or free standing a/c, fresh air would only come from opening doors or windows. Using a centralized a/c has a fresh air intake and that could be the cause of your problem. The solution would be an anti-odor filter.
I hope this helps.
Jun 02, 2009 | Heating & Cooling
Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner Logo
188 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
