Question about Lexmark X2350 All-In-One InkJet Printer
My Lexmark x2350 won't recognize the new ink cartridge!
I have tried everything - unplugging, powering off, reinserting,nothing works, HELP, please!
  • Anonymous Feb 24, 2009
    hey mine is same it will not work i have a cartridge in and it says nothing is in :O
  • Amanda Frontz Jan 29, 2012
    I too am having trouble getting my Lexmark X2350 to recognize a Meijer brand cartridge that is suppose to just like a Lexmark 1. I am goin' flip'n nuts try'n to figure this out...HELP!! Please & Thank You!!
  • 23 Answers
Hi,Ive had this problem a few times with the 2300 series theres no easy answer to it if your getting an unsupported cartridge message or cartridge not recognised you either have an empty or a faulty cartridge,or a damaged contact on the printers ribbon where the cartridge mates to the printer.Bill.
Posted on Feb 26, 2009
My Lexmark X2350 will not recognize a replacement ink cartridge
Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from the ink that is specially formulated by Lexmark and these type of cartridges often result to poor print quality and/or may cause damage to the printer itself. Reliability of these type of cartridges is very poor.
It is highly recommended to use genuine Lexmark cartridges for the most optimal output experience. Lexmark printers work best with genuine supplies.
Jan 29, 2012 | Lexmark X2350 All-In-One InkJet Printer
I have an Lexmark x3350 and bought a new black ink cartridge a couple weeks ago. I was working fine till now, printer screen is showing Left cartridge incorrect. I unplugged everything, tried ...
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Good Luck!!!
Sep 22, 2011 | Lexmark X3350 All-In-One InkJet Printer
Ran out of ink, changed the ink and the printer prints a blank paper...checked the ink everything is good...still nothing printing??
Make sure you are inserting genuine Lexmark cartridges.
Try to re-seat the cartridges into the printer. Remove the cartridges > close the printer cover > unplug / re-plug the printer into the power source to reset it > when the printer turns on, firmly reinsert the cartridges. Try to print a document again to verify that the problem is fixed.
If that doesn't help, try to clean the print cartridge nozzles. Open the Lexmark Solution Center on your computer by going to Start menu > Programs / All Programs > Lexmark Z600 Series > Maintenance tab > Under Select a Maintenace tool, select Clean to fix horizontal streaks. > click Print. Then try to print a document again.
Sep 13, 2011 | Lexmark Z615 InkJet Printer
I am trying to change my ink, when I open the scanner the cartidge do not come to the middle so I can change it what can I do to correct this problem.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Sep 06, 2011 | Lexmark X2350 All-In-One InkJet Printer
Lexmark x2350 scanner only scans a black page
Try to open the printer cover and remove the print cartridges from the printer. Close the printer. Then, unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Try to scan again.
Aug 16, 2011 | Lexmark X2350 All-In-One InkJet Printer
How to install a new ink cartridge in Lexmark 2350 printer/scanner
Perhaps the Lexmark X2350 User's Guide will be able to help you. Just click on this link to download: http://bit.ly/bNOTdZ. Scroll to Replacing the print cartridge, Page 52, for the instructions on how to install your new ink cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Sep 15, 2010 | Lexmark X2350 All-In-One InkJet Printer
X2350 All-In-One InkJet Printer: How do I change the ink cartridge in a Lexmark x23...
Here's the User's Guide for your reference. Just click on this link: http://www.lexmark.com/publications/pdfs/2007/2300/2300-en.pdf . Scroll to Maintaining the All-in-One, Page 52, for instructions on how to change/replace the cartridges on the Lexmark X2350. In some cases, even when the printer is on and the cover open, the carrier doesn't position to the center. Unplug the printer from the power source. With the cover open, hold the solid white tape in the middle inside the printer. Other end of it is connected to the carrier. Slowly drag the carrier to the center loading position. Load the cartridges. Close the covers. Plug printer back to the power source. Hope this helps.
May 07, 2010 | Lexmark X2350 All-In-One InkJet Printer
Change ink cartridge now nothing works!
I had a similar Lexmark all-in-one before. It may be stuck because you may have replaced the cartridge when it was off. Try to unplug it from the power outlet for 5 minutes. Then, plug it back in. IT should work now.
Oct 21, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 Paper Feed Troubleshooting
Check to make sure there arent any stray paper fragments in teh paper path. Also try taking a pencil eraser to the paper pinch rollers GENTLY.
Mar 26, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark x2350
I had the same problem. Put a new cartridge in and now get the error. Lexmark support couldn't fix the problem so they tried to give me 20% off on a new one. yeh right!
Nov 29, 2007 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 All-In-One InkJet Printer Logo
1,394 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
