Question about Sony STR-DE197 Receiver
How do i hook up my tv, speakers, and receiver together. i bought it with out an instruction book. marie
  • 1 more comment
  • Chuck May 11, 2010
    i have your manual of receiver i just need your tv model?
    what is the model of your tv so i can give you a good description
    or charles_farrah@comcast.net
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    what is exact model of Sony receiver to provide you instruction manual.
    Problem Solver:
  • 19 Answers
Usually, you look for the "audio out" on your TV and connect it to the "audio in" on your receiver and, then, connect your speakers to the speaker connectors on your receiver. I have the same receiver but I don't have my instruction book in front of me so I will watch to see if your problem has been solved and, if not, try again with my manual in front of me.
Posted on Oct 30, 2009
How to hook up a Onkyo DV-CP500 5 DVD/CD to a Onkyo AV receiver HT-R500 and a Hitchi 43FDX15BV2G005104 HDTV?
From what I find on the internet, the Receiver and the DVD player do not have any HDMI connections. Therefore, I'm using the S-Video connections. The best way to hook these components up is the following.
DVD player - Use an S-Video Cable on the OUTPUT and connect this to the S-Video Input on the Reciever. Also, connect the two audiot OUTPUTS (red/white) on the DVD player to the RECIEVER's two audio INPUTS (red/white)
RECEIVER - Use an S-Video Cable and connect to the S-VIDEO MONITOR OUTPUT and this will connect to the TV's S-VIDEO.
Speakers will connect to the Left Right Front Speaker, Left Right Rear Speakers, and Center Channel. The sub woofer needs to be connected to the Sub woofer/PreOut terminal on the Receiver.
Oct 23, 2014 | Audio Players & Recorders
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
How do i connect my av30 speakers to my Toshiba tv? I have tried everything and am unable to get sound from the speakers. I have 2 sets of these speakers and would love to listen to my tv with them. I also...
Connect left and right audio outputs on rear of TV to corresponding inputs on rear of your Pyle receiver. You may have to go to the initial set up procedure on your Toshiba TV to disable internal speakers and direct audio output to the Pyle receiver.
Dec 04, 2017 | Audio Players & Recorders
I need help hooking up my system from cable box to old toshiba 52 inch tv does not have hdmi on tv red, green , blue wires i also bought today a sony blue ray player speakers are not working ...
Please indicate the brand and model of your receiver, BD player and your speakers. Basically, you just need to connect the cable box and blue ray player to the receiver. The 5.1 speakers should be connected to the blue ray player, then another set of cables from your BD player to your TV. When you want to use the speakers while watching TV, you need to turn on the blue ray player too.
Sep 15, 2011 | Audio Players & Recorders
I just bought a LG 55le5400 TV. How do I hook up a older receiver that does not have HDMI, or sound for my speakers?
You can use rca cables to hook it up or use the toss link cable if your receiver has that.
Mar 14, 2011 | LG 55LE5400 TV
Can not get audio from tv to receiver
You may need to assign the optical audio input to the selected source. Also check to see if the input mode for the selected source on the receiver is set to Auto or Digital.
Sep 29, 2009 | Denon AVR588 Receiver
Hi, I just purchased a used set of 901s with the original active equalizer. they are both series VI and were bought together. Unfortunately, the man misplaced the installation instructions for the...
If no Amp is used, connect jacks ( Left, Right) from your receiver output to Bose equalizer Input ( L, R) where it says Amplifier. Then also under where it says Amplifier, connect jacks from Output to your speakers. This would require the type of speaker wires that are RCA (plug in, red and white) on one end bare wire on the other to the speakers.
I don't know what the output is on your Kenwood, but if it's low watts, an amp is much better to crank those Bose. It's a different connect with an amp. Go L &R from the receiver to Equalizer as before, then from equalizer to amp Input where it says Tuner. then hook bare speaker wires to back of amp to Bose speakers.
You should have full use of Bose controls. The Monitor button is for an extra component that can be hooked up on the back, right side of equalizer.
Jul 15, 2009 | Bose 901 VI Main / Stereo Speaker
Need to know how to hook the 2 together and then to a hd tv
Connect the dvd player to one of the video inputs of the tv. Connect the left and right audio outputs from the tv to an input of the receiver. aux, or whatever you choose. Simple.
Apr 23, 2009 | Televison & Video
Trouble with the hooking up wiring for receiver, DVD/VCR combo and satellite to new DLP TV.
Jar50, lacking model numbers for your TV and Satellite, I would suggest connecting your DTV Satellite OPTICAL out to your 65"DLP. Connect your 65"DLP OPTICAL out to your Onkyo TX-DS484 OPTICAL in. If you are using the DIGITAL COAX, just substitute the instructions above from OPTICAL to COAX.
Hope this helps.
Aug 28, 2017 | Onkyo TX-SR803 Receiver
Sony STR-DE197 Receiver Logo
110 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
