Question about Maytag Dryers
Dryer blower does not appear to be working.
The Maytag dryer that I own is taking up to 8 hours to dry a load of clothes. When I looked at the blower, I was able to spin it with the dryer off. Is that normal? Or should the blower spin when the motor turns it. Thanks.
Errol
  • Maytag Master
  • 3,361 Answers
Replace your blower wheel.
Hopefeully no other parts have been dammaged.
Posted on Feb 23, 2009
Maytag epic electric dryer takes a long time to dry clothes
check your vent by removing the vent from the back of the dryer run a normal load in the dryer and if it runs normal you have a crushed vent hose or it is plugged somewhere
Nov 17, 2013 | Dryers
My dryer does not shut off and doesn't get hot. It takes almost 5 hours to dry a load of clothing.
Sorry to say but it sounds like the heating element is on its way out... Happened to ours and repair was more than a new dryer so we brought a new one
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Since a month ago our dryer takes a long time to finish a load, A load which used to take 45 minutes to finish now takes close to 2 hours to finish.
check all of your duct work clean it out make sure there is no lint in the duct work going from the dryer to the wall also check the duct work going from the wall to the outside of the house
Dec 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
My maytag dryer does not dry clothes, it takes upwards of two hours to dry a normal load. Tub turns, timer works, exhaust vent is clear, just doesn't dry.
Your dryer needs a new heating element. Any good Maytag repairman can put one in. If you are very handy you can do it yourself but if not it should not be an expensive job.
Mar 22, 2010 | Maytag PYE2300AY Electric Dryer
My Maytag Dryer model DE308 takes 2 hours to dry a load of clothes. I have air flow, but after an hour, the clothes are still damp. THe dryer does not have the heat that it used to. I know that with the...
Good day,
Your right on the heating element.
If your positive the vent system to the outside is clean, then
Remove the front panel of the dryer, and inspect the blower wheel. If worn on the shaft(slipping), it needs replaced.
2. Remove the whole front panel to access the blower housing and the chute going to the lint filter. Clean as needed. (common problem).
3. If everything checks clean, then the thermostat that is mounted on top of the heating element canister is the most common problem but is only one of the thermostats.
Maytag uses a lot of air versus heat for drying. That is why it is important that part of the system is correct.
Mar 14, 2010 | Maytag Dryers
Maytag MDE8600AYW takes way too long drying clthes
either your house vent is plugged, or the vent in the dryer by the blower is plugged. when the vent is plugged, even partially, the moisture is not leaving the dryer. It will take a long time to dry, and the top of the dryer will get hot when the vent is plugged. Clean the house vent and check down below the lint trap by the blower, then it will dry fine again.
Oct 09, 2009 | Maytag MDE8600AY Electric Dryer
Take too long time to get cloth dried
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Jul 02, 2009 | Frigidaire GLER341A Electric Dryer
Maytag atlantis takes hours to dry one load.
Most common problem is something blocking the venting process, either somewhere in the vent tube itself,,, or somewhere in the venting system inside the dryer, like maybe the blower fan.
Mar 13, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
98 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
