Camera will not transfer pictures to copmuter plug it in turn it on and nothing! Any help?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
SOURCE: images
This is no problem. Its work also in this condition bcz you import your image and in importing your all images in camera transfer to your pc, if you want to safe your images in your camera please use a card reader to copy your images in your pc. After that your all images also safe your camera.
I hope its very helpful for you
SOURCE: nikon coolpix L18. Can't put pix on comp. format card
I suggest you to remove the card from the camera and use a memory card reader to transfer the pictures to the computer. Note that the memory card should be formatted in the camera. Once the pictures are transferred you can reinsert the memory card to the camera and then format it in the camera.
SOURCE: Transferring pictures
Make sure you have the drivers installed for your camera. If the computer can't detect it, then thats the reason. You should be able to find the drivers on Nikon's website. Good luck.
SOURCE: pictures will not transfer off the camera
Here's a silly suggestion for you... is the "lock" engaged on your memory card? It will be a small sliding lock portion on the SD card. If yes, unlock it and try again.
SOURCE: pics won't transfer to PC
WHEN YOU GO TO MY COMPUTER DOES IT SHOW UP AS A NEW DRIVE IF SO RIGHT CLICK ON IT IT SHOULD SHOW YOU YOUR PICTURES .IF THAT DOESNT WORK UNINSTALL YOUR CAMERA USING THE ADD REMOVE HARDWARE AND SHUT DOWN YOUR COMPUTER AND RESTART IT THEN RE-ENSTALL USING THE ADD/REMOVE HARDWARE RESTART COMPUTER WITH CAMERA ON IT SHOULD RECONIZE IT
i have the exact same thing... plug it in. turn it on. beeps. nothing happens.
