Question about Sharp AL 1631 Copier
RED LIGHT AE153 E RED TRIANGLE LITE ON NO OWNERS MANUAL WHAT DOES IT MEAN IT RUNS BUT DOESNT COPY AND TONER GETS QUITE WARM
    President:
  • Sharp Master
  • 990 Answers
Hello Ms; The red Triangle lite means you need feed them toner, they are hungry !
Posted on Feb 24, 2009
I want to know the solution to a sharp ar-5316 i refilled the toner after the toner was empty and the red triangle is still blinking, what should i do?
Does the toner cartridge have a electronic chip on it? if so you could refill it all day long it would not change once the chip say the i am done the cartridge is done. Sorry.
Try this site as a start and get a new OEM cartridge
http://olsonbros.com/sharp/parts/list.htm
Jan 28, 2016 | Sharp Ar 5316
I have a Sharp SF-2020 pedestal copier. The red triangle dots appeared above the yellow digital copy #. Prior to this, it took over a minute for the copier to "boot up". I added factory toner...
Hi r_finch424,
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Hope it helps.
Thank you for using FixYa.
Aug 29, 2011 | Sharp SF 2020 Copier
What does it mean if a ds lite red light doesnt show up when you are playing it? The green light is on and plays fine but then when battery gets low the green light goes off and stays off but the red light...
This is OK the Red LED Has just gone out... simply just keep an eye on time if you think that it might die soon plug it in... there is not much that you can do to fix it.
Nov 21, 2010 | Nintendo DS Lite Console
Sharp AL-1631 copier. Red flashing triangle no owners manual. Dosn't work. Help
Flashing triangle of dots? for your reference, this is, and always has been, the universal symbol for add toner.
...and here's your manual:
http://www.sharpusa.com/files/cop_man_AL1641CS_1631.pdf
Feb 25, 2009 | Sharp AL 1631 Copier
RED LIGHT
If the signs that is blinking red which is shape like triangle , it is the toner cartridge indicator. The toner cartridge is empty.Try to pullout and check the toner cartridge, if it is light in weight it is already empty.
Feb 23, 2009 | Sharp AR-153E Copier
Will not print
Yeah thats an easy one. Your really out of toner, the density sensor is seeing a light development patch, and the firmware ( machine operating software) does not have a clue what to do.
I suspect, ohhhh about 99.99999999999999999999999999999999999 percent sure if you replace the toner cartridge your machine will warm up, set up in a minute or 2 and run like normal.
I have seen that time and again on that machine, The software sometimes simply doesnt know what to do with a light copy indication.
The out of toner sensor is a window type sensor, so if there is a little remaining toner on the sensor, yet the density sensor looking at the patch on the drum is light, the software has no clue what to do, so the machine runs, and runs, and runs, and runs...... A new toner cartridge is a almost 1000000000000000000000000000000000 percent fix.
Oct 16, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Red light
The triangle dots are "need toner"
the cylinder is "need new drum"
the jagged line W means "paper jam"
Sep 16, 2008 | Sharp AL 1631 Copier
Paper feed problem
please check if the rubber roller that pulls the paper inside the machine check if it is clean because after long use this roller becomes so smooth ddue to dust and doesnt take in the paper , first clean it ,wipe with wet towel  try again
Oct 27, 2007 | Xerox 5305 Copier
Sharp AL 1631 Copier Logo
130 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
