Question about Canon EF 100mm f/2.8 Lens
Would a canon 100mm f2.8 be a lense to use to shot a basketball game sitting under the goal?
  • 38 Answers
Well it could be used but you may find the auto focus to be too slow and the aperture of f2.8 a bit dark for indoor sports. That lens is best used in the role it was intended — macro photography. Take a look at the 85mm f1.8 USM or the 100 f2 USM. They are reasonably priced and offer greater AF speed and low light ability.
Hope this helps
Posted on Mar 03, 2009
I have a Spalding 60 inch glass basketball system. It was lowered all the way down and now it can't be raised because it's too low. How do I fix this?
In-ground Basketball Goals: Spalding 88369 NBA ... > In-Ground Basketball Goals
The Spalding 88369 NBA Inground Basketball Goal System includes a 60'W x 36'H Pro style extruded aluminum framed Tempered Glass or Acrylic backboard ... Click here to download the Spalding 88369 Basketball Goal Owner's Manual
Jul 26, 2015 | Spalding 79307 Basketball Backboard and...
Service manual for canon 100mm 2.8 usm
go to canon web site to download
Apr 30, 2014 | Canon Cameras
I have a canon 100mm macro EF 2.8 lens. When I attached it today to my camera (EOS 400d) it will not auto focus correctly. The working sound it makes is even a different sound to the normal focusing...
Your 100mm lens autofocus not may be due to autofocus flex cable inside the lens damaged. It is replaceable part. You may have to contact service technician. However when you switch to manual mode it should focus & click. Try it.
Sep 29, 2017 | Canon 75-300mm f/4-5.6 III USM EF Lens
I have a Canon 100mm macro lens used on a Canon EOS 40D Camera. The problem I have is that the images produced seem to be not pin sharp, even when using a tripod and the mirror lockup function on the...
It seems that you have either a faulty lens or one which is performing outside of the minimum quality standards. You have clearly done everything possible to try and eliminate all other causes. Looking at the firmware updates for your camera, none of them mention an issue involving your lens but you may wish to ensure that you have the latest firmware anyway.
All you can do is to contact Canon customer care to request that the lens is exchanged.
Sep 07, 2010 | Canon 100mm f/2.8 Macro USM EF Lens
I just purchased a new Olympus E 420 I am trying to take pictures of a basketball game and they are blurry. Can you help me select the correct mode and shutter speed.
I assume you're shooting indoors and that you can't rig additional floodlights. Unfortunately, you're probably not going to eliminate all of the blurring. Here are some tips on reducing the blur.
Raise the ISO. This will increase the noise, and you'll have to make the call as to the trade-off between noise and blur.
Set the exposure mode to Aperture-priority. Open up the lens as far as it will go. This will guarantee the fastest shutter speed under the circumstances.
Anticipate the action and time it for the peak. A player driving the lane will blur. A player hanging at the top of his jump shot won't.
If you're sitting in the bleachers, forget about using flash: you're too far away for the flash to reach the subject. If you're on the sidelines (and flash is allowed), you can experiment with flash.
You didn't specify the lens(es) you'll be using. One of the things that separate the professionals from the rest of us is the speed of their lenses. Of course, if Sports Illustrated is paying for the pictures, the photographer can afford $2000 lenses.
Feb 20, 2010 | Olympus E-420 Digital Camera
I have a canon 100mm EF macro lens with a loose rear element section. How do I solve it?
You can TRY to see if the screws are loose on the back of the camera around the rear element.  Sometimes they look flush but need a couple of gentle turns to bring everything where it should be.  If possible you should use a JIS (Japanese Industrial Standard) Phillips screwdriver so you don't strip the screwdriver head.  Don't use too much force - these are precision instruments and only need a certain mechanical tightness - too much can cause harm.
Unfortunately, if it's not those rear end screws, you'll have to send it in to Canon.  Fortunately Canon is very good about repairing lenses, even if they are slightly out of warranty.
Good luck
May 16, 2009 | Canon EF 100mm f/2.8 Lens
Vivitar series 1,70-210mm tele photo.when camera is tilted,lense will move in or out.drives me nuts
It's called "zoom creep" and not all that uncommon. You can try sliding a sheet of paper or a thin film under the ring to tighten it up, or use tape to hold it in place once you've got what you wanted. I would NOT squirt any liquids inside to unlubricate it.
Feb 28, 2009 | Vivitar Telephoto 100mm f/3.5 Macro Manual...
Canon 70-200mm f/2.8 IS lens not focusing
I have had to replace the focusing servo motor is these before. The problem of seeking without locking in may mean the same for your lens. Do check for a dirty filter on the front and look to see if the rear optic is dirty or cloudy first. I'm assuming other lenses work fine on your camera.
Jan 05, 2008 | Canon EF 70-200mm f/2.8L IS USM Autofocus...
Canon EF 100mm f/2.8 Lens Logo
116 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
