Question about Intel Celeron -D 2.26Ghz Computer System PC Desktop
M y screen reads Boot from CD!!
I couldn't use my PC beause when i swithch it on Black screen appears with Boot from CD:Failure appearing.This sentence here appear as well ''For Realtec RTL 8139 (A/B/C)/RTL8130 PCI Fast Ethernet controller.
PXE-E61:Media Test Failure.
  • Nayacalevu Feb 23, 2009
    Thank you for your help!!!It does work.Thanks for your kind assistance.
  • Intel Master
  • 3,051 Answers
Hi there
uyou can press the esc key and go from there or if you can boot into bios and under boot change the way the computer boots up have it boot from the harddrive first and than the than the cd rom than the a drive than save and exit and reboot ok please let me know how this works for you best regards mike
Posted on Feb 23, 2009
  • Michael Thomas
    Michael Thomas Feb 23, 2009
    you are very welcome and hope you come back to us here at fixya for all of your computer issues
    best regards mike
  • Intel Master
  • 4,806 Answers
Hi there.
Go into the bios (F2 on start-up) once in the bios set the first boot device to hard drive or HDD, hit F10, save and exit, the computer will restart and should boot from the hard drive.
Good luck and thanks for using Fixya!!
Pro-book 4520 won't boot. I switched on this morning. The windows (7) logo appeared, then blue/black screen and cursor only. Would not boot up. Ran diagnostics which said all OK. Still won'
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
Aug 13, 2012 | HEWLETT-PACKARD ProBook 4520s Notebook PC
How to format my computer
insert operating software DVD in your DVD drive
restart your Pc
press Del key (.)
select boot menu
select 1st boot device
black screen appears with "CD/DVD"
at that time press enter
screen appears with :DVD CD Boot...."
at that time select enter
software installation
custom install
Jun 05, 2011 | Fujitsu Siemens SCENIC P300 PC Desktop
Reads boot disk failure 0
Boot disc 0 failure is usually indicative of the failure of the hard drive that contains the operating system. Make sure the hard drive is well seated into the cables and that the cables are seated onto the motherboard. If it all is well, then the hard drive has most likely failed and needs to be replaced.
May 19, 2010 | Dell Dimension C521 PC Desktop
Hi. Well there are not any reason for this problem to appear. Done nothing regarding disk problem. Anyway when I boot the process stops with the black screen with "Verifying DMI Data...... Boot from...
You are seeing a failure to read your hard drive.
Now you need to troubleshoot that. Your hard drive could have gone bad or you can boot from a system disk (that would be a Windows system disk) and run chkdsk.
If you need help doing that, just ask. I'd be glad to help you further.
May 23, 2009 | Foxconn 945P7AA-8KS2 Motherboard
Whenever i try to open my login page it appears in arabic
  • Insert Operating system Installation CD in the CD drive or any medium driver available in the system.
  • Restart the computer
  • The message will be desplayed in the black screen "press any key to boot from the CD", then press any key immediatelty and wait until the blue screen appears.
  • In the blue screen will appear "INSTALL NOW, REPAIR"; you must select 'INSTALL NOW' option and wait.
  • Another options will appear, then you must go for "REPAIR option this time.
  • the installation cd will verify the system files available in the hard drive and those that are in the INSTALLATION CD.
  • After sometime the dialog window will appear and click 'settings' and select 'languages' tab and select the proper language required.
  • click apply and ok.
From Mtha
May 15, 2009 | Facebook Social Network
Boot failure at USBd checkpoint
There are 2 steps you can do to fix the problem
1. Change the USB Emulation Setting in the BIOS
NOTE: It is recommended to disconnect any USB devices before performing the following steps.
Restart the system.
Wait until the Dell Logo appears.
At the Dell Logo screen, press F2 right away to enter the System Setup.
The System Setup screen will appear.
Press the down arrow key to highlight Integrated Devices (LegacySelect Options).
Press Enter.
A small box with a list of devices appears in the middle of the screen.
Press the down arrow key to highlight USB Emulation.
The default setting is On.
Press the Space Bar on your keyboard to change the setting to No Boot.
Press the Esc key.
The small box disappears.
Press the Esc key again.
A small box with list of options appears in the middle of the screen.
Make sure that Save Changes and Exit is highlighted in blue.
Press Enter.
The system will then restart.
The recommended changes have now been made to the BIOS.
2. Reset the Dell Dimension desktop System Setup (BIOS) to factory defaults.
Restart the system.
The Dell logo screen appears.
Press F2 to enter the System Setup (BIOS).
The System Setup screen appears.
Press the ALT + F key combination.
Press the Esc key to Save and Exit.
Press Enter to Save changes and exit now.
The BIOS is now set to the default settings.
Apr 02, 2009 | Dell Dimension 3000® Pentium® 4...
Blank screen appears on the startup with only cursor on it
The Acer Recovery CDs do not set the Boot flag on the hard drive. I had to manually set the boot flag to on using GPARTED Live. After restarting using the GPARTED CD, you can manage the flags under the partition drop down and click on the Boot flag. After exiting GPARTED, I rebooted the laptop and no more black screen....fixed!!
I hope this helps others.
Jan 27, 2009 | Acer Aspire 4720 Notebook
MONITOR
This usually indicates that there is a harddrive failure or problem with BIOS. When the machine is booting up, get into BIOS and check to make sure that it is recognizing the hard disk and that it is configured to use the hard disk as a boot device. If all that appears to be OK, you might want to try booting off of your Windows CD (go back into BIOS and set your CD player as the boot device). When you're booted up, check to see if you can read data from your hard disk. My guess is that you will not be able to, and that would indicate a hard drive failure. Newegg carries them at a very respectable price.
Apr 13, 2008 | Computers & Internet
Reformatting pc
what you need to do is put the XP cd in the cd or dvd drive first,then, when the pc is booting up press either F2 or Del depending on bios and the cmos setting screen will appear. Go to advanced cmos settings and the top line normal reads 'first boot device, this will be set at HDD or hard disk, this needs to be changed to cdrom. When you have changed it, save settings and exit, the system will now reboot and an option to boot from cd screen will appear, you then press Enter to boot from cd then follow the instructions to format or install windows.
Aug 27, 2007 | Dell Dimension 4600 PC Desktop
No bootable cd in AT API CD-ROM - Packard Bell E2315
Shut the machine down. Start her up As soon a POST comes up[the black and white screen] start holding down F8 You will get a screen come up with varios options. use uodown arros to Start on last known.. that worked Press return.
May 28, 2007 | Packard Bell Easy One Silver 2101 Notebook
Open Questions:
as some sites suggest about cheat for igi game i tried it and make changes under Project IGI- I'm going in Cheats----hi friends in this game it is difficult to get the blood/medipack to get this use the folowing instruction. 1)first go to the igi installed folder then go to weapon folder u will find some folders like Ak47,binoculars,colt anaconda,medipack etc. 2)then go to Ak47 folder you will find a folder like weapon the open in hex editor u will find a string like weapon_id_Ak47 by using hexeditor edit the string to weapon_id _medipack. then similarly go to medipack folder u will get a folder like weapon then open in hex editor edit weapon_id_medipack to weapon_id Ak47 the save it. 3)when u will kill a soldier u will get a medipack. for hex editing i installed HEXED30f.zip software and changes in hex file as i described above but due to mistake my igi game not start well aND , SHOW A error like igi stopped and shows problem detail Problem Event Name: APPCRASH Application Name: IGI.exe Application Version: 0.0.0.0 Application Timestamp: 3a1d74c6 Fault Module Name: StackHash_169c Fault Module Version: 0.0.0.0 Fault Module Timestamp: 00000000 Exception Code: c0000005 Exception Offset: 00000000 OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional Information 1: 169c Additional Information 2: 169c69b50cca39ebafad90cf9acfe712 Additional Information 3: 166e Additional Information 4: 166ed9faa1184e606930c56f1ef84d85 please send solution ... or reply
Dec 31, 2010 | Intel Celeron -D 2.26Ghz Computer System...
Intel Celeron -D 2.26Ghz Computer System PC Desktop Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
