Question about Maytag Performa PAV2200
MAYTAG DRYER MAKES BUZZING SOUND WHEN I TRY TO TURN IT ON, BUT WILL NOT ACTUALLY TURN ON. I PULLED IT APART AND MADE SURE ALL OF THE LINT WAS REMOVED FROM SYSTEM. iT SPINS BETTER NOW, BUT STILL WILL NOT TURN ON??
  • Maytag Master
  • 3,361 Answers
A buzzing sound when you press the start button is a indicator of a bad motor if no other obstruction is found.
It seems you have eliminated other obstructions.
Posted on Feb 23, 2009
I have a Westinghouse 505E dryer and it won't
if its making a buzzing sound the motor is stuck its proberly full of lint it need taken apart and vac out around the motor / or it could be motor bearings worn or the belt brocken you will need to take apart to hav a look
Dec 09, 2011 | Dryers
Maytag Neptune gas fired dryer motor does not turn makes buzzing sound
Dryers are turned by a belt, and belts break. You have to take the back off and look. The belt goes around the whole drum. It if broke, it will probably be on the bottom. Make sure the drum turns easily by hand. It could get jammed on something, or the bearing could go bad.
Sep 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer model PYE2300AYW dryer runs gets hot stops. when I try to turn it back on it makes a noise and won't start back up. What could be wrong?
It sounds like your motor is bad. you could take the dryer apart and clean off the lint on the motor and see if that helps but it sounds like i said the motor is faulty.
Mar 24, 2010 | Maytag PYE2300AY Electric Dryer
Maytag gas dryer, model #MDG7600AWW does not turn on
a thermal fuse should read shorted until it gets hot .. the buzzing you hear might be the motor running but not turning the drum .. that would be a broken belt .. the motor is spring loaded to keep the belt tight ..the belt is long .. it goes around the drum and down to the motor ... belts are available at many appliance parts shops .. changing it is not hard for someone handy .. a bit more than you would want to handle if you are not mechanically inclined ... on some maytags the whole front of the dryer comes off with just two screws near the bottom .. that makes servicing much easier ..
Sep 12, 2009 | Maytag Dryers
Dryer won't start all the time
First.Unplug the dryer.
Disassemble the dryer and clean the lint from the motor and blower wheel.
Check the wiring connections to the motor.
If this does not correct your problem you have a bad motor.
Mar 11, 2009 | Maytag Dryers
Maytag neptune dryer wont restart mde 3000 aya
Your dryer needs a new motor. It should cost about $200-250 including labor. Call a local repairman - not a national company. Give him the model number and ask him to bring the motor with him.
Mar 31, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Mdg4000 GAS
bad rollers could be making black dust but the real problem is the tumblers seals letting the roller dust get into the tumblers and on to you clothes.
Black or brown makers are from the faulty or damaged tumblers seals you have one in the frount and one back...
I can help you strp by step if you want to do it yourself.
Dec 23, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Washing Machines Logo
142 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
