Question about Whirlpool Washing Machines
Washer leaking MODEL # LRS7233DQO LEAKS OIL AND WATER ON THE FLOOR HOW DO I REMOVE THE REAR PANEL ON THIS UNIT
  • Whirlpool Master
  • 3,361 Answers
It does not remove from the rear.
There are 2 phillips screws at the back right and left of the control panel.
Remove these screws and lift the control panel forward then backwards.
Unplug the lid switch wire.
Remove the 2 metal clips holding the cabinet to the back panel.
Remove the cabinet by pulling it forward.
Then you can view the leak from the tube causing your problem.
Posted on Feb 23, 2009
Leaking water
What is the model number of your unit?
Nov 20, 2012 | Washing Machines
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 | Freezers
I have a Kenmore heavy duty washing machine model C110. When the machine has a full load and a high water level, it leaks, but when the level is lower ( small load ) it is ok. Also under the machine on the...
The water leak is from the white tub cover on top of the tub. The seal needs replaced.
The oil is from the transmission.
I honestly would replace the washer.
Jan 12, 2010 | Kenmore 24032\24036 Top Load Washer
MOdel 110.92579110 leaking water out bottom of
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92579110
LEAKING:
See the Sears site sub-components for the agitator, basket and tub. It's possible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
The illustrations also show how to remove the transmission.
OIL
The black oil / fluid that you see is likely coming from the transmission.
Since it seems to be "spraying" around the inside of the cabinet, I'd assume that it is leaking from the top seal between the transmission and clutch.
See the following for a parts breakdown of Whirlpool top load direct drive washers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you look at page 15, you'll see a Seal, Gearcase Cover. It is possible that that is the cause of your transmission leak.
The rust on the bottom of the transmission may (hopefully) be simply caused by the water leak.
I'd remove the gearcase cover (8 bolts) in order to check the gearcase cover seal, and to check the oil level. The Whirlpool transmission takes about 15oz or 80-90 weight oil.
Oct 17, 2009 | Kenmore Washing Machines
Water is not filling in tub, leaks to the floor. hoses from faucet are good, no leak there
Check the connections from the water inlet mixing (control) valve to the tub. Access to the valve connections can be acquired (usually) from the rear of the unit, and access to the tub connection can be obtained from either the rear port, or by removing the front panel. I had a brand-new Maytag washer leak on its very first load because the hose clamp on the tub inlet line was loose. I tightened from the rear access port.
If these connections and other hose connections are good, I would begin to suspect a main bearing seal or spin bearing and seal, and would depend on your specific make and model. Repairs in this latter category can be both time consuming, expensive, and may require special tooling.
Oct 05, 2009 | Washing Machines
Machine leaks when clothes are washed but not
this could be a simple issue or a severe issue.
if you feel adventurous disconnect unit, and remove Rear access panel. inspect the rear bearring at the pulley, check for oil leakage and water residue. if there is water around the bearring the unit requires an overhaul. if nothing you should be ok.
it could be a disconnected vent at the top of the machine.
remove front access panel and inspect all rubber boots and connections for water.
this is best done just after washer has leaked, inspect where water is comming from.
there are many things that could be causing this.
Jun 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
I have a kenmore front load washer model number 4174104200 and water is leaking onto floor.
Can you describe WHERE the leak may be coming from? If the leak is coming from the front area of the washer, it may be the door bellow (rubber gasket), or the drain pump. You will need to open the door and pull back the folds in the rubber gasket and inspect for cracks or tears in the rubber. To inspect the pump, you need to remove the bottom panel under the door and look for any leaks inside the unit. The drain pump is in the front, directly under the wash tub. Also check all hose connections. If the washer is leaking from the rear area, check the fill hoses and drain hoses for cracks or holes. Make sure all hose connections are tight. The fill valve is another possiblity too. You will need to remove the top panel to view the valve to ensure it is not dripping. Please verify your symptoms and let me know. I hope this helps.
May 01, 2009 | Washing Machines
LEAKING WATER PUMP
you need a new pump if you go online and time in http://www.appliancepartspros.com/Appliance-Parts/Washer-Parts/index.aspx the new pump is like 33 bucks
Feb 24, 2009 | Whirlpool Washing Machines
Duet washer, water leaks out onto the floor, when not running.
warter seeping through valve remove power cord. them cut off water at wall remove 3 t20 screws from back of top panel slide panel toward rear to remove. remove hoses and electrical connections from valve remove 1 t15 srcew from back of rear panel to remove valve replace with part # 8181694 for about $50
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
