Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
Automatic "shut off" not turning off
Hello, I have a Hoover SteamVac Spin Scurb. I have just used it for the first time and noticed that when the recovery tank was full the automatic "shut off" came on and the suction was reduced. The owners manul says that when this happens to empty the recovery tank and then put it back into the steam vac and it should resume cleaning. Well I emptied the recovery tank and once clean I put it back into the steam vac and I still have no suction. I have checked many times to see if I replaced the recovery tank correctly and it is correct. I am wondering if there is something else I need to do to get the Automatic "shut off" to turn off so that I can resume cleaning. Please help me . Thank You.
  • 294 Answers
Check the filter in the tank, if a dual V model you will have a screen, if not a dual V move the foam filter down about 1/4" to help.The lid on either model needs to be securely in place, as well as locking the left and right latches. On the Dual V model, check the hose door on the front.
Posted on Mar 01, 2009
Why will my hoover spin scrub steam vac upholstery attachment not suction?
With this model, check all hose connections and recovery tank lid. if you have good suction before you put on the tool it may be the tool that needs service. inspect the tube under the recovery tank for the round gasket and the filter inside the tank.
Aug 26, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
Hoover steamvac shooting sparks from motor
the motors shot some times i have fixed them if it hasn't been ran to long let me know im sure i have a motor
Dec 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Automatic shutoff red ball in recovery tank rises to top when recovery tank is about 20% full.Thus we are only able to use the steam cleaner for about 2 minutes before having to empty the recovery tank....
Your cleaner should have a foam sock around the float cage in the recovery tank. Remove the foam sock and rinse it out with clean water. If these are very dirty, they may cause the airflow to be disrupted, causing the float to raise prematurely.
Oct 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover spin brush model f5914-900 wont draw water back out of carpet
Please remove the recovery tank and check and see there is a black rubber ring seal on the large vacuum tube that rises from the base to meet the bottom corner of the recovery tank. This rubber seal may have fallen off the tube and be found laying under the hood. It seals the vacuum source to the recovery tank.
Oct 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steamvac not picking up water
you don't have the recovery tank lid on correctly.
Jul 19, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
My hoover steam vac is not releasing the cleaner
http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
Godbless
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Possible cause
Possible solution
• Solution tank not firmly in place
• Make sure tank is securely locked in
position
• Solution tank empty
• Refill tank according to instructions for
surface being cleaned
correctly
• Make sure lid is firmly in place
• Pump needs to be “primed” (when
using tool)
• See “Before using tool” section, p. 13
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Recovery tank not working
recovery tank empty where do you look to see where the hair ball is so i can clean it
Mar 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steamvac Deep Cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40578&thid=661545
Hoover SteamVac Deep Cleaner
Posted by Alex987 on Jun 10, 2008
I can't seem to figure out how to use it =(
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5807 SteamVac Wet/Dry Vacuum. Well, there are 2 tanks, one is the water solution tank that is on top and the other is the water recovery tank of which is on the bottom. You use the trigger assm to release the water and the Hoover SteamVac works the best on the pull back. You can spry the water going forward but pull it back very slowly and let the brushes do the scrubbing for you and the dirty water pickup. There is a ball in the dirty water pup tank that will rise to the top and stop the water from coming in, @ that point you need to empty and rinse out the recovery tank and re-install. If you run out of solution the top tank cap or cover is the measuring cup to determine the amount of solution – usually it is one cap full and extremely hot water, there is a switch for the carpet and the upholstery, if the handle is in the released position then the brushes down below should be moving – just look in the brushes window and see if they are moving – if the handle is in the upright position then you can remove the attachment hose and then use the attachment and the revolving brushes will stop. I hope this will help you in working with the Hoover SteamVac. If not contact the Hoover Co and get an owner’s manual and give them the model # and serial #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
The automatic shut off
Check the filter on the inside of the lid for the dirty water tank. It needs to have a 1/4 in. gap from the top of the lid to the top of the filter.
Oct 13, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
163 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
