Question about Kenmore Ovens
Ove wont work
Every time you turn it on it gives " -F4- "
  • Kenmore Master
  • 3,361 Answers
Most likely a bad oven sensor.
Posted on Feb 23, 2009
Oven wont light gaves F4
Hi, the F4 error code means Open or shorted oven temperature sensor (RTD)..
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 20, 2010 | GE 30 In Freestanding Gas Range ...
I am trying to unlock my oven
Often you lock the ove to clean it and it gets so hot inside that it will not unlock til it cools. give it some time. good luck!
Aug 31, 2010 | Ovens
Had a power surge and the clock went blank and ove will not turn on but the oven light still works. maytag built in single oven
It is quite possible that the power surge has damaged the electronic components in the controller or timer, thus rendering it unuseable.
It would mean replacing board or timer.
Hope this helps ypu.
Dec 18, 2009 | Ovens
Dacor CPO130W F4 fault
f-4 on decor ovens mean the oven temp sensor is bad. replace the oven temp sensor and it will be fine
Nov 27, 2007 | Dacor ECS127 Epicure Stainless Steel...
The F4 error code generally means a bad temperature sensor or a short in leads to the sensor. Under room temperature conditions the resistance should be approximately 1100 ohms. If you are not comfortable around electrical apparatus and/or don't have an ohmmeter, you will need to contact an appliance repair technician. GE typically places a trouble shooting guide in the top of their ovens behind the touchpanel. You will have to remove three screws in the bottom of the touchpanel to open the panel. Be sure and turn off the power before opening the touchpanel!!!
Aug 23, 2007 | GE JTP85 Electric Double Oven
Replace the temperature sensor. It is usually located in the upper left corner of the oven (inside). Two screws hold it in place and, if you're lucky, you can pull out the junction to disconnect the old and connect the new one. Do this with the power off, Please!
Aug 22, 2007 | GE JKP86 Electric Double Oven
luvin, F4 is a shorted oven sensor. Under 950 ohms. Should read 1060 ohms at room temp. The sensor is located in the upper left hand corner of the rear oven wall. Remove the 2 screws and it will pull out enough to remove the connector. Catriver.
Aug 22, 2007 | GE JKS05 Electric Single Oven
Mewood What part did you call "thermostat"? If you?re talking about the device which operates the oven temperature, your oven does not have such thermostats. It has two oven temperature sensors (one in each oven) and a control board (ERC). An error code "F4" will be displayed along with a beeping sound if the ERC determines an open oven temperature sensor circuit. It can be the sensor itself or the wires that connect the sensor to the ERC. The F4 message will not be displayed in the time of day mode. To get access to an oven sensor and wires, the oven has to be removed from the cabinet. Then you have to remove the rear cover. Then unplug the oven sensor and check the resistance across the oven sensor. It?s supposed to be about 1100 ohms at room temperature. If the resistance is incorrect, the sensor is bad and needs to be replaced. If not, check all the wires from the oven sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC, but most likely the problem is with the wires and/or connections. Part number for ERC is 62965, part number for oven sensor is 62593. back.
Dec 14, 2006 | Dacor ECS230 Epicure Stainless Steel...
Oven not working
is this a gas oven or electric?
Oct 24, 2006 | Electrolux EOD5310 Electric Double Oven
Ovens Logo
42 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
