Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Tester - Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
  • Microsoft Master
  • 4,806 Answers
Tester 2
Posted on Feb 23, 2009
Head lights dim and lose power steering when at low speed light stop sign or parking
The most common cause of these problems is a loose slipping fan belt. For most cars the belt is held tight by a tension-er. This is a pulley that is spring loaded. Usually the tension-er applies the force to the back side of the belt. Tension-er has been known to stick and not flex with the belt allowing the belt to slip. Also if the belt is worn it can slip. Another possibility is that one of the accessories, on the belt circuit are having trouble rotating prohibiting the belt to operate freely. Careful inspection of the belt will determine its condition. With the hood open listen to the motor at idle and the sound of a squeaking belt is an indication that the belt is slipping. To test for the tension-er with the engine off try tapping in the direction of tightening the belt on the tension-er with a rubber mallet. Start the engine and observe if the condition is still the same. If it has corrected the problem than the tension-er either needs to be cleaned or replaced.
Nov 15, 2015 | Cars & Trucks
MAX ER 1100
Hi ,our company is Wuxing baisi office consumable co.,ltd . we can offer Max ribbons . like Max ER-1100 ER-1500 ; Max ER-2200 ER-2500 ER-3100 ER2200 ER2500 ER3100 /Max ER-IR102E. Please contact me at
We can do B2C, B2B business.
Mar 06, 2014 | The Times Max ER-1500 Electronic Time...
Er 1 error
Dear Sir:
adjust the speed sensor, see the diagram attached, clean, and tight the connector very well.
2) Test the input voltage motor, if there are the motor need repair or replace.
3) Test the output voltage from the main motor board for the input of motor, if there are NOT, the board is faulty.
4) After fix it, run the software calibration, for diagnose, and troubleshooting.
sincerely. God bless you
Apr 24, 2012 | Avanti Exercise & Fitness
Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
My sharp cash register ER-A550S stop working
The letter H appears in the screen. The register will not respond. Any idea to what the Letter H means?
Apr 10, 2010 | Sharp XE-A402 Electronic Cash Register
My amp goes into protection mode when i turn on my car. It gets hot too. I had 2 kicker 12" l5's and blew the subs with that amp, could i just have a simple problem with the amp? What are all my options?
Protection LED on, no output? Amplifi er is very hot = thermal protection is engaged. Test for proper
impedance at the speaker terminals with a VOM meter (see the diagrams in this manual for minimum
recommended impedance and multiple speaker wiring suggestions). Also check for adequate airfl ow around
the amplifi er. Amplifi er shuts down only while vehicle is running = voltage protection circuitry is engaged.
Voltage to the amplifi er is not within the 10–16 volt operating range. Have the vehicle’s charging and electrical
system inspected. Amplifi er will only play at low volume levels = short circuit protection is engaged. Check
for speaker wires shorted to each other or to the vehicle chassis. Check for damaged speakers or speaker(s)
operating below the minimum recommended impedance.
No or low output? Check the balance control on source unit Check the RCA (or speaker input) and
speaker output connections.
Jan 29, 2010 | Kicker ZX10001 Car Audio Amplifier
Software for Sharp XE-A201 Cash Register
You need the PC Link software for your model.
All of these manuals can be downloaded at:
sharp ER-1017 Service
sharp ER-1072 Service
sharp ER-1073 Service
sharp ER-1074 Service
sharp ER-1075 Service
sharp ER-1076 User Service
sharp ER-1077 Service Programming
sharp ER-1077
sharp ER-1077
sharp ER-1772 Service
sharp ER-1772s Service
sharp ER-1871 Service
sharp ER-1872 Service
sharp ER-1873 User Service
sharp ER-1875 User Service
sharp ER-1910 User Service
sharp ER-1911 User Service Programming
sharp ER-1911s User Programming
sharp ER-1920 User Service
sharp ER-1921 User(R) Service Programming
sharp ER-1921s Programming
sharp ER-1970 User Service Programming
sharp ER-2000U Service
sharp ER-2100 User Service
sharp ER-2370 Service
sharp ER-2371 User(R) Service Programming(R)
sharp ER-2385 Service
sharp ER-2386 Service
sharp ER-2386s User
sharp ER-2395 Service
sharp ER-2396 Service
sharp ER-2720 Service
sharp ER-2722 Service
sharp ER-2722A User Service
sharp ER-2742 Service
sharp ER-2742A Service
sharp ER-2770 Service
sharp ER-2782 Service
sharp ER-2782A Service
sharp ER-2905 Service
sharp ER-2908 Service
sharp ER-2910 Service Programming
sharp ER-2970 User Service
sharp ER-2975 Service
sharp ER-2980 User Service
sharp ER-2980S Service
sharp ER-3100 User Service Programming
sharp ER-3110 User Service Programming
sharp ER-3115 Service Programming
sharp ER-3120 User Service Programming
sharp ER-3550 Service
sharp ER-3600 User Service
sharp ER-3630 User Service
sharp ER-3712 User Service
sharp ER-3721 Service
sharp ER-3731 Service
sharp ER-3732 User Service
sharp ER-4100 User Service Programming(R)
sharp ER-4110 User Service Programming(R)
sharp ER-4100S Service
sharp ER-4110S Service
sharp ER-4550 Service
sharp ER-4630 User Service
sharp ER-4633 Service
sharp ER-4700 User
sharp ER-6740 Service
sharp ER-8700 Not Available, do you want to swap?
sharp ER-A150 User Service Programming
sharp ER-A160 User Service Programming
sharp ER-A170 User(R) Service Programming
sharp ER-A180 User Service Programming
sharp ER-A220 User Service Programming
sharp ER-A227G Programming
sharp ER-A250 User Service Programming
sharp ER-A310 User Service Programming
sharp ER-A320 User Programming
sharp ER-A330 User Service Programming
sharp ER-A410 User Service Programming
sharp ER-A420 User Service Programming
sharp ER-A430 User Service Programming
sharp ER-A440 User Service Programming
sharp ER-A440S Programming
sharp ER-A450 User Programming
sharp ER-A450S User Service Programming
sharp ER-A450T User Service Programming
sharp ER-A460 User Service Programming
sharp ER-A470 User Service Programming
sharp ER-A490 User(R) Service Programming
sharp ER-A510 User Service Programming
sharp ER-A510s Service
sharp ER-A520 User Service Programming
sharp ER-A530 User Service Programming
sharp ER-A550 User Service Programming
sharp ER-A550s User(R) Service
sharp ER-A570 User Service Programming
sharp ER-A610 User Service Programming
sharp ER-A650 User Service Programming
sharp ER-A650S Programming
sharp ER-A670 Not Available, do you want to swap?
sharp ER-A670S Programming
sharp ER-A750 User Service Programming
sharp ER-A770 User Service Programming
sharp ER-A770II User
sharp ER-A770M User Service
sharp ER-A771 User Service Programming
sharp ER-A850 User
sharp ER-A880 Not Available, do you want to swap?
sharp UP-3300 User Service Programming
sharp UP-3300M Service
sharp UP-3301 User Service Programming
sharp UP-600 User Service Programming
sharp UP-700 User Service Programming
sharp UP-800F User
sharp UP-810F User
sharp UP-820N User Service
sharp UP-X300 User
sharp UP-X500 User Service
sharp XE-A101 User Service Programming
sharp XE-A102 User Programming
sharp XE-A106 User
sharp XE-A110 User Service Programming
sharp XE-A120 User Service Programming
sharp XE-A130 User Service Programming
sharp XE-A201 User Service Programming
sharp XE-A202 User Service Programming
sharp XE-A203 User Programming
sharp XE-A206 User
sharp XE-A20S User Programming
sharp XE-A212 User Service Programming
sharp XE-A213 User Programming
sharp XE-A301 User Service Programming
sharp XE-A302 User Programming
sharp XE-A303 ? Programming
sharp XE-A401 User Programming
sharp XE-A402 User
sharp XE-A406 User
sharp XE-A40S User Programming
sharp XE-A505 User Programming
Dec 30, 2009 | Sharp XE-A402 Electronic Cash Register
I have a LG GR-L207DUZA ''er ff''
i dont have the manual however.. this could be your freezer fan is perhaps seized.. you can test this by leaving your freezer door open to raise the temp and wait ti see if your fan comes on.. this may take upto 10 minutes so be patient
Nov 11, 2009 | LG Refrigerators
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
