You need a new timer. The cam (dial) is round with different cuts in it. When the cam advances, the keys, like a piano, will make contact with the cuts. If the dryer is not advancing, then the timer has gone bad. The contacts are staying closed keeping the switch of the dryer on. This is a VERY easy part to replace... No need to hire anyone. I can walk you through it.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Is this in time dry or any setting?
