Question about Franklin Industries Franklin Chef Ice Cube Machine FIM400
Ice machine not working Franklin FIM35
When you push toggle switch to start making ice; you hear a beep and a audible click, then nothing, it appears that the fuse is good....
    New Friend:
Did you ever find a solution? mine does the same thing and drip tray is empty.
Posted on Oct 31, 2013
  • Sherry
    Sherry Oct 31, 2013
    The nice man at fixice.com told me the solution. My problem was the sensor clips on the drip pan on top of the compressor.
  • Sherry
    Sherry Oct 31, 2013
    The wires on the one of the clips were shorting out. As soon as I lifted the clip off of the pan the alarm stopped. Although my pan was dry except for a tiny bit of water in the bottom it was shorting by just touching the side of the pan. I didn't want to leave it unclipped in case it ever did overfill so I rigged the clip on so that the bare wire was not touching the sidewall but was inside the pan so it could sense an overfill. Thank you nice man at fixice.com!
2 Suggested Answers
SOURCE: FranklinChef FIM35 Not making ice
I drained the water from the plug on mine and it started to work. The black plastic crew plug about 2 inches from the bottom of the unit, there is a rubber stopper you have to pull out.
Posted on Jul 21, 2009
How do I clean my FLM70 ice maker
Google Franklin chef FIM70 Ice maker- compactAppliance.com, click on page scroll down page until you see Download product owner's manual ( PDF ) this will give you step by step instructions on how to clean your machine, The machine should be cleaned every 6 months. If cleaning dose not help with the problem than you need to look into a harvest problem.
Dec 04, 2013 | Franklin Industries Franklin Chef FIM200...
Dear Sirs, >
Get the info needed from the manufacturer of ice maker.
Apr 16, 2017 | Franklin Chef FT386 Refrigerator With Ice...
Franklin FIM35 continues water alarm even days after water drained.
I searched and searched for a fix and here was mine. The sensor wire was shorting out on the drip pan (which was not wet to the touch) above the compressor causing the alarm. I removed the clip and re-rigged it so the bare wire is not touching the sidewall but is positioned so that it could still sensor and alarm in an actual overfill.
Aug 23, 2009 | Franklin Industries Franklin Chef Ice Cube...
When you press the ice dispenser no ice
the switch you push activates a couple of things. One is a solenoid that opens the door the other is a relay that moves the ice to the crusher.
Since you aren't hearing any sound....and are not getting any ice, I would suspect the switch is bad.....
But before you start taking things apart....try pushing it with your finger rather than a glass.
Check for the length of travel? can you feel or hear a switch click?
Jul 07, 2009 | Frigidaire FRS6R5ESB
Jun 27, 2009 | Franklin Industries Franklin Chef Ice Cube...
Ice maker will not make ice
This is a Franklin ice maker and here is a link to the manual http://www.franklinchef.com/pdf_info_phase_4/FIM35%20C%20Manual.pdf.
Nov 14, 2007 | Carrier Beverage Air DD68C Commercial...
Franklin Industries Franklin Chef Ice Cube Machine FIM400 Logo
390 people viewed this question
Top Franklin Industries Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Franklin Industries Kitchen Appliances - Other Expert? Answer questions, earn points and help others
