Question about Pentax Optio M20 Digital Camera
When i turn on my camera, the lense comes out, fluxuates in and out, beeps and goes back inside the camera sutting off. Sometimes the shutter sticks and will not close comepletely? Will dut or grit make the shutter do this? How do i fix it?
  • 2 more comments
  • alvamiga Feb 28, 2009
    When I turn on my Pentax M20, the lens comes out, then the camera takes the lens back in and turns off. Picture view mode (pressing play+ power) and connecting by USB works fine, but I cannot take pictures.
  • rachel787 Mar 06, 2009
    When I switch it on the lens comes out, fluctuates in and out a little, makes a buzzing sound and then closes off. The batteries are new. I recharged them to make sure it's not a power issue. Help!!
  • Anonymous Mar 21, 2009
    I have exactly the same problem. I think it could be caused by something obstructing the lens. I never reaches the full extended position.
  • Anonymous Apr 10, 2009
    the lense comes out when camera is turned on and then closes all up and turns on again
    i think i might have got sand in between the lenses
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Aug 21, 2012
bmwrider
  • 215 Answers
SOURCE: Pentax optio 60
Your shutter is driven by a small motor attached to the lens assmbly. It could be that which has died or more likely you have a sticky shutter. A small knock or a drop of soda can stop them from opening. Try switching on and very gently with a cotton bud see if you can help open the shutters. Whatever you do don't force them and force them out of shape. You may have to do this a few times to get in sync with the power up sequence but if you can get both shutters to open fully you should be in business. If they keep sticking I've seen one guy glue them open. Personally I'd rather fix them so they do their job.
Posted on Jul 12, 2006
  • 685 Answers
SOURCE: Fresh batteries..turns on and within 3
Send back for repair, there is a fatal electronic problem that must be repaired. this is not something you can do yourself, since it requires major parts be diagnosed and replaced.
Posted on Nov 24, 2009
  • 11967 Answers
SOURCE: Scratching noice while the lense move out
My Optio S does the same thing but works perfectly otherwise. Don't worry about it.
Posted on Feb 25, 2010
  • 11967 Answers
SOURCE: lense will not stay out
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 29, 2010
t00nz
  • 4738 Answers
SOURCE: When you turn the camera
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Posted on Jun 30, 2011
I dropped my camera and now when turning camera on the shutter comes out for about 2 seconds then it beeps and then it goes back in, I can view photos but not take any.
The most of cases problems is your camera lense wont come out properly. it's appear to be a electronic problem but it's defenetly a mechanical problem. do do as i say. turn on your camera and after lense came out quickly remove the battery. after that camera lense move out shake it well. shake your camera well. your target should be remove if ther any blocking thing the way your camera lense come out. if this way wont work you have to open your camera and check your mechanism. some time it can be broken lense.
Jul 09, 2009 | Casio Exilim EX-S880 Digital Camera
Shutter fires when film advance lever is used.
The problem you describe is common with the EM. I have one myself sitting on the junk pile for the same reason. The body is made of plastic and the plastic around the advance lever is a week point. Your body, unfortunately is not repairable. But there is good news. Because of the low cost of a replacement EM on E-bay (under $30), you should consider keeping your lenses and buying a new body (the standard 50mm f1.8 EM is superbly sharp for a low end lens). Since the EM lenses are interchangeable with later models, you could consider a later model used body. Many are selling for fire sale prices.
Sep 23, 2008 | Nikon EM 35mm SLR Camera
S600 : Beeps 3 times when i try to turn on
i had the same prob. the shutter was stuck out. all i did was put slight pressure on the shutter (dont touch the lense) and it clicked back into place. no more beeps
Aug 11, 2008 | Cameras
Samsung L200 Digital Camera
I took it to a camera shop. It cannot be fixed.
Your guy probably figured that out too. He kept the line open for 2 hours before I finally closed the screen. I really don't think his 5 minutes should cost me 14.95.
Jul 28, 2008 | Cameras
Camera beeps and won't turn on
Try playing with the lense I had the same problem. I would turn it on and the screen was frozen, the three beeps then it turned off. I played with the lense since it was sticking out and I tried turning it on again and it worked. :]
Jul 24, 2008 | Casio Exilim EX-V7 Digital Camera
It wont stay on
the same thing happend to me just now... you have to wiggle the lens untill it goes into place then it should retract when you turn it on. :]
May 14, 2008 | Polaroid i531 Digital Camera
I have broken my HP Photosmart R817
I just fixed mine and what came out of the end of the lense housing was the shutter assembly. Your camera will still work but the shutter will not operate for protecting your lense.
What was on the ground from the shutter assembly looked like six parts but actually there's eight:
1 - Front round plate (what you see if shutter assembly was still in the lense housing).
2 - Hair size springs that hopefully stayed in the sides of the front round plate. IF NOT OR EITHER ARE LOST, THE SHUTTERS CAN'T BE SET TO CLOSE SO SKIP THE STEPS BELOW ABOUT INSTALLING THE BLADES.
1 - back round plate (black with four tabs).
2 - Larger L-shaped blades.
2 - Smaller L-shaped blades.
Place the front round plate with cosmetic (engraved 'PENTAX...) side down and look at the inside for two round mounting posts on the left and right. You will be using the larger of the two posts on each side for placing the L-shaped blades.
Place the larger L-shape blades with the hole end onto the posts. Blades should swing freely and their backs match with the shape of the inside of the front plate when open.
Place the smaller L-shape blades on top of their respective larger L-shape blades with the hole end onto the same posts used in the last step. Blades should swing freely and their backs match with the shape of the inside of the front plate when open along with the larger L-shape blades.
Springs (long ends) will need to notch into the smaller L-shape piece end (nearest the hole/post end). This is a real trickly part of the assembly and I used two tools like large pins or needles to pry the spring into the notch. If you can't do this, no sense in even leaving the four L-shaped blades inside of the front round plate since the shutter will not close properly without the springs.
Align and snap the back round plate tabs onto the front round plate. The shutter assembly is now ready to put back into the lense assembly.
MAKE SURE THE CAMERA IS IN THE OFF POSITION AND THE LENSE ASSEMBLY IS RETRACTED!
Align the front of the shutter assembly with the engraved wording properly oriented (not sideways, not upside down, etc.) and press gently into the lense assembly until completely in the end of the housing.
If blades were installed properly, they will open when the camera is turned on, and close when the camera is turned off.
If blades were not installed, the empty shutter assembly (back round plate snapped onto front round plate) can still be pressed into the lense housing...the shutter will just not work and the lense will always be exposed. Actually, this is one helluva lot easier than fixing the shutter assembly and not the end of the world for your camera's operation!
Mar 23, 2008 | HP Photosmart R817 Digital Camera
Shutter
sounds like the lil motor that is in charge of opening and closeing the shutter might have shorted out causing it to stick, or it could have just simply burnt out or striped the lil gears on the motor. If the shutter moves alil bit i would say you probably have a short in the shutter motor.
Dec 05, 2007 | Fuji Zoom Date 60 35mm Point and Shoot...
HELP! dropped camera, lens won't go back in, shutter won't close
I have a camsung L830 that had similar problems and and after I would turn it on, it would beep three times and turn off....but I somehow fixed the lens by turning the camera on and then either pushing/pulling on the part the stickes out and hopefully it might activate the mechanism and it'll go in...that's what happened with mine...the shutters still won't close though. But I'm happy I can use my camera now.
Sep 24, 2007 | HP Photosmart R927 Digital Camera
Pentax Optio M20 Digital Camera Logo
93 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
