Question about Gestetner Office Equipment & Supplies
Gestetner 3502 - how do I offload info saved on Doc Server?
I have a Gestetner 3502. It has a functioning document serverandan integrated hard drive. I am unable, however, to retrievetheinformation on the drive. I have attempted to set HD upassecondary on desktop (running XP). I don't recognize the portsonthe motherboard, although it is designed to accommodate ISDNandLAN. There is the appearance of a USB pinset on the board, butitis unlike the standard (plus the tech would've been cuttingedge,right?)
How can I transfer my saved documents?
Why is it removed from the copier? why not copy directly from the document server to your hard drive while still connected to the copier?
I don't think you will be able to read that drive from your pc even if you were to get it connected. I believe the formatting would be unrecognizable.
At the same time, it's not something that I have experimented with...this is just my 2 cents
Posted on Feb 25, 2009
Our gestetner 3502 as an error code sc990. How can I fix this?
Replace the drum if not possible then go to copy sp mode dial 2208 and change the copier sencer mode to pixels mode
Sep 13, 2017 | Gestetner Office Equipment & Supplies
Entering code sc 542
Fuser error code press clear modes (yellow) 1 0 7 then hold down the stop key for 5 or so seconds screen will change, cycle power
Nov 23, 2013 | Gestetner Aficio 1035/g/p, 1045/g/p...
I have a Seagate Free Agent Desktop External Hard Drive. I cannot get any of my computers to access the drive. I fear the drive has crashed.
get linux puppy and boot the cd while your hard drive is plugged in, if you can mount under puppy linux and see your info choose the info you need and offload onto an external usb, copy the files over, dont move them as if disk is corrupt you could lose info, then reformatt the drive, just to let you know there seems to be alot of hard drive issues with seagate lately
Feb 14, 2011 | Seagate Computers & Internet
Please wait appears
Most likely this is a hard drive failure. This is especially likely if your machine has the network print and or the document server and fax options installed.
If you let it sit with "Please Wait" long enough does it ever come up with the wrench light or service code?
May 12, 2010 | Gestetner DSm622sp Digital Imaging System
I need to replace hard drive for a ricoh copier 1045. How can I get the software for the hardrive, and what is the maximum size of the hard drive?
No need for software. The standard hard drive size is 10GB. I don't remember the exact limit but the machine will only recongnize a certain amount so it will do you any good to buy a larger capacity drive. Just get the smallest/cheapest one and you'll be fine. These take the smaller "laptop" size drive in case you did not know. Other than that just install the new drive and let the machine do the setup. If your old drive failed then keep in mind you will have lost any document server files, scan destination or fax destination info and will have to re-enter that info.
Good Luck
Feb 23, 2010 | Ricoh Office Equipment & Supplies
I'm a teacher. I store all my documents on Simpletech pininfarina 500GB and take the drive from work to home. I need to be able to transform the documents as I go but it doesn't let me ad or delete any...
they may be "read only" right click on one of the docs (assuming they are Word files) go to properties - untick the box that says read only.
when you saving files - go to save as 97 to 2003 doc
the global template (normal.doc) may be saving as read only
Nov 14, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
I am having problem w/ saving a document to hard drive
Need more info, can you save as a .txt or .rtx ? Have any other problems with saving to the drive? Have you tried to-- save as-- and put your doc in a new folder or rename the doc?
Jul 16, 2009 | HP Compaq Presario F500 F700 and G6000...
Document Server Not Holding Document
Hello sir; The answer for you is NO, you better save in CPU.
May 26, 2009 | Gestetner DSM 651 Copier
Wanting to convert ms word doc 2007 to 2003
Open the document in 2007, use the "save as" feature but select Word 200???? as your Type or Format you would like to save the document as, I woiuod create a folder Named 2003 word files, and put the newly saved as docs in there, so you will be able to use the same file name an not overwrite the 2007 files. That is ONLY a suggestion
Apr 03, 2009 | Microsoft Windows Server Standard 2003 for...
Every time I take things from my flash drive. The pictures will transfur ok. The doc. in work looks like an empty folder. I was able to open it once. But I would loose it.
Which document proggy do you have and what type of file are you saving to your flash? doc? rtf? If you are able to save a document to your hard, it must be a file type problem.
Jul 26, 2008 | Computers & Internet
112 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
