Question about Porter Cable Porter-Cable 4216 12" Deluxe Dovetail Jig Combination Kit
Dovetail leave a 'light gap'
I have a 24" jig from Porter cable about 12 years old.
Recently a client reject a job because he felt the dovetails were 'filled' and not precisely cut.
I have set and reset the depth of cut and no matter what I do there is a slight bit of light at the end of the dovetail when the side and face are put together.
I can provide pics if it will help
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
This may not be related to your jig. It may be movement in the vertical axis resulting from:
  1. The router bearings being worn allowing the bit to move up and down.
  2. The router bearings worn allowing the spindle to deflect side to side which changes the bit height slightly (cuts on the edges, making the cut a hair deeper).
  3. The router collet or router spindle worn, allowing the bit to move during cuts.
  4. The jig guide plate deflecting or no longer flat.
  5. Excess vibration in the router causing the wood to move in the jig.
To check the bearings; try routing the cut with a straight bit first to clear the wood for the dovetail bit. Then cut with the dovetail bit (a new one preferably) using very light feed pressure. Is the joint tighter? If so then the bearings are worn. Have the router serviced or replace it.
Check the end-play by pulling on the router shaft, does it wiggle slightly in and out? If so this is your problem. Have the router serviced or replace it.
Be sure the wood is flat and the faces planed parallel, if they aren't the dovetail line will be straight but when you assemble there will be slight end gaps in sections of the dovetail.
Posted on Feb 28, 2009
How to use a Stanley 92870dovetail jig
Sir,
There is an interesting man I believe can stimulate your enthusiasm to be a success. Please? Take the time to travel to this link and watch this short but novel approach to building drawers.
Frank Klausz Dovetail Drawer DVD intro
As far as your saw. I would build a base jig to match the depth and width of your work piece, follow your layout leaving half the line. look over Kluasz' library and your sure to be as wide eyed and smiling as you will when your projects come together.
I have always advocated. New wood smells good. Fare . Well.
Apr 26, 2014 | Saws
Rockwell dovetail model 5008 manual
http://documents.dewalt.com/documents/English/Instruction%20Manual/Porter-Cable/883490-893,5008.pdf
Nov 04, 2013 | Saws
Is the Dewalt dovetail jig 6212 any easer than a Leigh jig as im stuck at the moment what to buy?
This is strictly a personal preferance but I would go with the Dewalt.Ihave been using a large variety of tools and equipment for forty years and I firmly believe in Dewalt and Milwaukee. Thank you.
Mar 11, 2011 | Garden
Are the 7 degree dovetail bits, that come with the jig, the only size that can be used or can a 9 degree bit be used?
Hi, W/D at your service.
Apparently, there are several types of bits compatible with your model.
Here's a link that gives you a better idea:
http://www.toolup.com/porter-cable_4216_12-deluxe-dovetail-jig-combination-kit.aspx
Best regards, --W/D--
Feb 23, 2011 | Porter Cable Porter-Cable 4216 12" Deluxe...
Where can I purchase an owner's manual for a Craftsman dovetail jig Model # 315-25710 A2044? Virgil
You might check this out, I found it in another forum. It looks like Ryobi made this dovetail jig for Sears.
1-800-525-2579 is their customer service line. I would ask for Ryobi Tech Services.
Nov 22, 2010 | Craftsman Saws
I need operating instructions
Here is a direct link to your owners manual. You can print it if you want a hard copy or you can order one from porter cable.
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=65507&typeId=14816&documentId=30657
Hope this helps.
Richard
Mar 09, 2009 | Porter Cable Porter-Cable 4216 12" Deluxe...
Need a manual for PC omni jig- original model
You will need your model #
Here is where to get your manual
Good luck and let me know if I helped
Jan 06, 2009 | Porter Cable 55160 16 Inch Omnijig...
Porter Cable Porter-Cable 4216 12" Deluxe Dovetail Jig Combination Kit Logo
290 people viewed this question
Top Porter Cable Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Porter Cable Measuring Tool and Sensor Expert? Answer questions, earn points and help others
